front tires sizes
  • suzukikid62
  • suzukikid62's Avatar Topic Author
front tires sizes
30 Jan 2011 21:04
#427271
Hey I am wondering what size is a lower profile front tire I have the stock 100 90 19 on it now. And I was wondering what size is not as tall that will still work good. I'm trying to get a little more clearance for my header. It is lowered. Id rather not rake it out and. Still keep it lowered. Looking for a good set of tires that will do good on the street and strip.
  • mjg15
  • mjg15's Avatar
Re: front tires sizes
30 Jan 2011 21:23 - 30 Jan 2011 21:26
#427276
Try to find a 100/80-19, I've never looked for that size so I'm not sure how common it is, but it would give you approx 10mm (3/8") additional clearance. A 90/90-19 should be available, it will be a bit narrower and also give you about the same 10mm of additional clearance. Not sure what bike you have, but you may also be able to use an 18" wheel from another Kaw model. A 100/80-18 would give you a good 3/4" more clearance than your 100/90-19.
'80 Z750fx
'81 KZ550A
'81 GPz550's, Too many!
'82 KZ1000R
'82 GPz750
'90 ZR550
Project photo album: s163.photobucket.com/albums/t289/mg15_ph...GPz-ZR550%20project/
s163.photobucket.com/albums/t289/mg15_ph...current=DSC01286.jpg
Last edit: 30 Jan 2011 21:26 by mjg15.
  • PLUMMEN
  • PLUMMEN's Avatar
30 Jan 2011 23:36
#427285
i wouldnt go any narrower on the front wheel if its a streetbike,you dont want the rear wheel pushing the front through a corner on a 500lb bike. B)
  • suzukikid62
31 Jan 2011 07:21
#427336
Its a 1978kz 1000 . It has spoke rims. So I don't know if theirs an 18 in spoke wheel for kz's but if their is I'd probably considered that
  • mjg15
  • mjg15's Avatar
31 Jan 2011 07:56 - 31 Jan 2011 07:57
#427346
A spoked wheel would be the easiest type to swap to an 18". You just have to get a rim and spokes that work with your hub, that eliminates all the other complications associated with wheel swaps (like spacing, axle diam, brake related mayhem etc.). Call Buchanans, they are not cheap, but they will know what you need.
'80 Z750fx
'81 KZ550A
'82 KZ1000R
'82 GPz750
'90 ZR550
Last edit: 31 Jan 2011 07:57 by mjg15.
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
31 Jan 2011 08:41
#427352
Your speedo will be off.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
  • suzukikid62
31 Jan 2011 09:39
#427388
How mich would it be off? And do you know the number and a ballpark number for how much it would probably be
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
31 Jan 2011 10:18
#427406
Nah, sorry.
1975 Z1 900
2004 KX125
