how do you remove the steering stem 82kz1000
  • bdydrppup
  • bdydrppup's Avatar Topic Author
28 Jan 2011 20:11
#426630
so how do i get this stem out? ive read about gring welds but at first glance i didnt see any. jus press fit? from top or bottom? thanks in advance guys
  • Motor Head
  • Motor Head's Avatar
Re: how do you remove the steering stem 82kz1000
28 Jan 2011 20:23 - 28 Jan 2011 20:25
#426631
Here are some pages from the Service manual.
Attachment Steering.doc not found
And yes I believe it presses out from the lower triple clamp.
Last edit: 28 Jan 2011 20:25 by Motor Head.
  • s3steve
  • s3steve's Avatar
29 Jan 2011 05:58
#426714
1973 Kawasaki Z1
1975 Kawasaki S3
2006 BMW R1200RT
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
29 Jan 2011 06:39
#426725
is it an aluminum or steel lower triple?
if steel you have to cut(grind or machine)the weld off and press it from the bottom up.if it is aluminum it will press from the top down.
hth,
  • bdydrppup
29 Jan 2011 06:45
#426726
it is the aluminum lower tree. thanks. thats what i was curious about. wasnt sure which way to press it
  • 531blackbanshee
  • Vendor
29 Jan 2011 07:29
#426733
you should be able to press from the top down.it should have a snap ring around the bottom of the stem that would prevent it from being pulled up through the lower tree when tightening it down on the bike (hopefully no one would ever try to tighten one that tight :blink: ).
i have a twelve ton press and have been able to pop out busas,zx9's,zx7's,ktm's,klx 110's,kx 65'65,katana's.some of em are pretty tite but they have all come out.
  • 531blackbanshee
  • Vendor
29 Jan 2011 07:31
#426734
it is always good to remember the forces that are present when the stem is mounted on the bike.the nuts and bolts on the top of the stem are always going to try to hold it all together,not pull it apart.
hth,
  • Hollywoodmx
  • Hollywoodmx's Avatar
13 Jan 2013 23:43
#567252
I'm trying to get mine out of the kz. I ground off the welds but I don't see the ring of the stem. How much grinding do you have to do? I have done a fair bit.
- 82 GPz1100injection
- 77 Kz1075 Supercharged
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
  • 531blackbanshee
  • Vendor
14 Jan 2013 10:59
#567312
alot !
those welds will go 1/4 inch deep or better sometimes.
i usually cut them out with the lathe.
  • Hollywoodmx
14 Jan 2013 12:20 - 14 Jan 2013 12:22
#567319
531blackbanshee wrote: alot !
Ok I was getting worried that the grinding actually melded/blended the seam together where I would'nt see the the separation of the the two pieces. Is that even possible? I'm using a 4" wheel grinder.
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
Last edit: 14 Jan 2013 12:22 by Hollywoodmx.
  • 531blackbanshee
  • Vendor
14 Jan 2013 17:31 - 14 Jan 2013 17:34
#567344
that is possible that the part line blends in.
but a smack with a hammer will jar it enough to show the part line,if your deep enough yet.
being as it was welded on,it will press from the bottom of the triple up and out.
Last edit: 14 Jan 2013 17:34 by 531blackbanshee.
  • Hollywoodmx
15 Jan 2013 00:43
#567398
531blackbanshee wrote: that is possible that the part line blends in.
Thanks Leon. Ya I was already worried about the melding so I did the socket and hammer and no luck. I wasn't sure if I was deep enough or not so I left till I got more info.
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
