offset sprocket
- kz1k
- You Cant Fix Stupid!
offset sprocket
24 Jan 2011 22:15
Hey guys. i couldnt help but notice the loss of threads for the nut available left on the drive shaft after mocking up my 5/8" offset front sprocket.
another concern i have is the gears. the drive gear does not slide all the way through the sprockets gear/gear grooves.
yeah my terminology is probably aweful, but i need to run these things by ya. thanks, Joe:)
1978 KZ1000A2
- MFolks
Re: offset sprocket
24 Jan 2011 22:55
My listing of sprocket makers, you'll have to contact them about how much offset you ned:
Sprockets And Drive Chains
www.sprocketspecialists.com/
www.sunstar-mc.com/home.aspx
www.rebelgears.com/
www.schnitzracing.com
www.jtsprockets.com
www.pmfronline.com/counter_shaft_sprockets.php
www.dgchassis.net/
www.rebelgears.com/
www.jtsprockets.com
www.dgchassis.net/
- Old Man Rock
Re: offset sprocket
25 Jan 2011 01:03 - 25 Jan 2011 01:29
Yup, realize you already purchased a "nosed" offset.
Picture would be helpful in depicting what you're speaking of...
Here's another source just in case....
Well made one piece (machined) Offset sprockets and SWING-ARMS for KZ's.... Both 530 and 630 pitch.
American Classics:
americanclassix.com/kawa_improvements.html
Mark's (MK1122) notes on his Gorgeous Kawi....
Offset Sprocket: ZRX12 see attached doc....
NOTE: File base isn't allowing me to update/download the doc file so just in case it doesn't attach here, PM me with your e-mail and I'll send it to you....
NOTE: Before buying another if required.... Frame all tightened up and rear rim centered?
Yeah, I realize you said "I'm going by Larry's measurements" but as we ALL informed you of, you changed your build from Larry's with additional cuts, swing arm years etc...
Too many variables where once you get this all squared up you may not require a 5/8" offset but only a 1/2" (12mm) offset....
As Larry also mentioned to you, he started with a 5/8" offset sprocket but had to mill it down on the back side a couple milli meters to get her aligned to rear sprocket... Basically more closer to 12-13mm...
Or as in Mark's case, had to mill the rear hub down as well to get the alignment spot on...
Think it out young man, you're on the right track....
Isn't modding fun...:laugh:
OMR
American Classics:
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 25 Jan 2011 01:29 by Old Man Rock.
