whats the diffenences in 73-80 and 80-82????
  • bdydrppup
  • bdydrppup's Avatar Topic Author
23 Jan 2011 06:03
#424611
ok so i have an 82 kz1000ltd. my tank was toast so i ordered a 79ltd tank off ebay. i knew the rear mount was different but it still had the really large tunnel and i liked the shap better. got it in and still wasnt large enough. big bummer.it hits the outside rails of the backbone. and all parts i find list the 81-82 in a diff catagory. so what are the diffences? body,frame,engine? that way maybe i can save my self some hard luck. wish there was a general discussion forum for this. thanks for the help in advance.
Re: whats the diffenences in 73-80 and 80-82????
23 Jan 2011 06:15 - 23 Jan 2011 06:17
#424615
Here's one option --- Zedder's Kawasaki Part Cross Reference Software. $24.95
Click > www.zedder.com/
Good Fortune! :)
Last edit: 23 Jan 2011 06:17 by Patton.
  • otakar
  • otakar's Avatar
23 Jan 2011 06:49 - 23 Jan 2011 06:53
#424627
There were basically three different versions 1973-1978 was pretty much identical with the only exception of the bore being bigger on the 1015 bikes over the 903 bikes. In 1979 -1980(81)the MKII came out and there were a few changes to the engine but the frame and most other stuff stayed almost the same, with the exception being the shaft drive. That had more engine changes, wheel and swing arm changes but many if not most parts were still interchangeable with the earlier bikes, with the main notable exception being the crank shaft and cam sprockets in the engine. In 1981 the "J" series was introduced and that was a completely different animal all together. Almost nothing is interchangeable with the earlier bikes.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Last edit: 23 Jan 2011 06:53 by otakar.
  • daskraut
  • daskraut's Avatar
23 Jan 2011 08:44
#424660
on an '82 LTD, you can only run a KZ1100 shaft tank and the stock tank. Hardly any parts from 80 and earlier will fit.
When in doubt, GAS IT!!
  • bdydrppup
23 Jan 2011 09:52
#424690
what about engine, drivetrain, sprockets and thing like that?
  • jus1975
  • jus1975's Avatar
  • www.tripleaperformance.com
23 Jan 2011 10:43
#424712
Sorry the tank didnt fit, but if you want to sell it let me know.
  • otakar
  • otakar's Avatar
23 Jan 2011 11:39
#424725
Every one of those parts you mentioned is completely different between the Pre & Post 81 engines.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • MFolks
  • MFolks's Avatar
23 Jan 2011 12:01
#424731
This might explain the engine differences:
www.aperaceparts.com/tech/techkz1000.html
