O.E.M. KZ1000 J1 fork seal trauma
- daskraut
21 Jan 2011 20:17
OK, you go to Kawasaki and buy fork seals with a part number you got from the Kawi website (p/n 92049-1295) and they are too big. I make arraignments to exchange them when the Kawi dealer gets another batch. In the mean time, I buy some online after again checking the part number(92049-1295).........and they also are too big!. There is no way that the part number is wrong since for 1981 both the J1 and CSR1000 use these seals AND the aftermarket has them listed as 38mm x 50mm x 8/9.5mm which is what I need. The 81GPZ1100 uses p/n 92049-1178 which is dimensionally identical to -1295 per the Z1 specialties website. The '81 KZ1000LTD calls for p/n 92049-1102 (superceded by -1178). Could Kawi have distributed alot of these improperly sized fork seals?. Do any of you have Kawi parts books to check this out?. The icing on the cake is i ride out 20 miles to the not-so-local Kawi dealer to pick up my replacement seals and he gives me 92049-1180...ANOTHER part number with the correct I.D. and O.D. but they are 1.5mm thicker and list for a KLR650. The fun never ends!
When in doubt, GAS IT!!
- MFolks
Re: O.E.M. KZ1000 J1 fork seal trauma
21 Jan 2011 20:32
Tried
www.z1enterprises.com
? they are very knowledgeable about these older Kawsaki's.
- Motor Head
21 Jan 2011 20:35 - 21 Jan 2011 21:02
So you have the old seals out, right? Then is there a part # on the seal? When I did mine I got aftermarket seals, can't remember the # but it was for 82 1000 K2 LTD.
Here is the Bike Master Part #: BM FORK SEAL 38X50X8/9.5
42-9018
This is the OEM # I get:
92049-1102
SEAL-OIL,FORK
42-9018
92049-1102
SEAL-OIL,FORK
Last edit: 21 Jan 2011 21:02 by Motor Head.
- daskraut
21 Jan 2011 20:56
no visible part number on the original seals. I did use aftermarket seals for the time being, but prefer O.E.M. for longevity.
- andy9802gt
- If it tastes that good, eat it yourself.
22 Jan 2011 04:25
longevity is relative. my question is do you really need a fork seal that last another 30 years? At $15 I think they can wear out in 5-10 years and you will have got your moey's worth.
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
- otakar
22 Jan 2011 07:50
The seal size is 38mm x50mm the thickness can be between 8mm-9.5mm. I have found that the K&S seals are the best, even better than the OE seals. They can be bought threw Z1E for $7.20 a set and # is KS16-1032. These bikes with these forks are EXTREMELY sensitive to pits. Even one tinny pit or scratch will make them leak like mad. I don't know why these forks are like that. Believe me, I have a lot of experience with these 38mm forks.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- OKC_Kent
22 Jan 2011 12:02
You may not have the original forks. Measure the tube and slider to confirm.
Cashion, OK
78 KZ650 B2 85,000+ miles
- daskraut
22 Jan 2011 16:34
These are GPZ1100 forks and mic out at 38mm. The dims are supposed to be 38mm x 50mm x 8/9.5 just like the aftermarket seals I installed measured out to AND Z1 enterprizes site mentions. The kawi seals measured I got in the package measured 40.3mm x 55.2mm x 10.8mm. These are the wrong seal. I wonder if anybody has some of these in the original bag and will confirm that mine are mislabeled.
- RonKZ650
22 Jan 2011 18:26
Having Kawasaki mistakenly package a part wrong is not probable, having 2 mistakes is a billion to one. Something else going on here.
- daskraut
24 Jan 2011 18:10
Ron, you are an optimist and I salute you, but there are many a dingbat working in the warehouses of the world!.
