rear sprocket help
  • kz1k
  • kz1k's Avatar Topic Author
  • You Cant Fix Stupid!
rear sprocket help
21 Jan 2011 08:37
#424094
hey guys. my rear sprocket finally showed. if i mount the sprocket with letters out vs letters in there is a 1/4" difference. does it matter which way i put it on? both sides are the same,(flat). this will help with my offset front sprocket. thanks.
1978 KZ1000A2
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
Re: rear sprocket help
21 Jan 2011 09:01
#424099
It shouldnt matter which way it goes on, but make sure that the chain has lots of clearance from everything around it once installed.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • kz1k
21 Jan 2011 09:12
#424101
B)
sweet, it saves me some fabrication!:woohoo:
1978 KZ1000A2
