Wire Rims for 1980 KZ750?
  • peterpicchi
  • peterpicchi's Avatar Topic Author
20 Jan 2011 10:06
#423831
Does such a thing exist?:unsure:
Im not too savvy with all of this so I couldnt really modify anything too extensively.
Maybe another models rims can be swapped right on?:laugh:
Thanks in advance,
  • Nebr_Rex
  • Nebr_Rex's Avatar
Re: Wire Rims for 1980 KZ750?
20 Jan 2011 10:29
#423837
Thanks in advance,
On which bike,
2 cyl. or 4 cyl?
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • otakar
  • otakar's Avatar
20 Jan 2011 10:34
#423841
Sure no problem. "Almost" all Kawasaki chain drive large bore street bikes have interchangeable wheels. I have a set from my KZ1000 CSR that would fit just fine. The notable exetions would be the KZ1300 and the 79/80 1000 shaft. (but those are shafts)and I said chain.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • steell
  • steell's Avatar
20 Jan 2011 11:10
#423849
Your wheels may fit a 1980 KZ750 four, but it would take some modification to make them fit a 1980 KZ750 twin.
Be nice if the OP had specified which 750 :(
  • cafekz750
  • cafekz750's Avatar
21 Jan 2011 11:25
#424123
So, what wire wheels would fit a KZ750 four cylinder with minimal fabrication?
1981 KZ750H2 - V&H 4-1 pipe, pods, jetted, clubmans, homebrew rearsets, 18" rear wheel and more.
Parting out a 1982 KZ750H3 to fund future projects
2 other non-Kawasaki motorcycles
  • steell
  • steell's Avatar
21 Jan 2011 14:47 - 21 Jan 2011 14:50
#424169
Look in the Filebase for the wheel bearing list and look for bikes that share the same wheel bearings with your bike. That will tell you they use the same axle diameter, the rest is easy.
Here you go, a direct link to it :)
kzrider.com/index.php?option=com_docman&...d&gid=151&Itemid=108
Last edit: 21 Jan 2011 14:50 by steell.
  • peterpicchi
16 May 2011 02:24
#451365
it's the 4 cylinder
  • peterpicchi
16 May 2011 15:03
#451467
4 cylinder
