Help with return spring!
- nbrider
16 Jan 2011 19:58 - 16 Jan 2011 20:05
I have a kz440, it runs perfect, but I cant figure out one thing. My rear brake won't return after being depressed. I need to manually lift the brake pedal back up. I went on ebay and bought a brake return spring as I know this is the issue (atleast I hope.. wasnt expensive anyways!). So I want to know if I need to remove the rear tire and go into the rear brake assembly or if it is a spring that attaches to the brake pedal arm.
I noticed at the top of the brake pedal, a knob like thing. Its hard to explain but it is a short rod (maybe a third of an inch) with a head on the top of it. Is this where the brake return spring should be?
Help please.
[/img]
Help please.
[/img]
1983 KZ440 LTD
Black paint- Soon to be something new!
Last edit: 16 Jan 2011 20:05 by nbrider.
Re: Help with return spring!
16 Jan 2011 20:21 - 16 Jan 2011 20:25
Could try kawasaki.com for some good info such as parts diagrams, part numbers, models sharing same part, availability, etc.
Here's a link for help with navigating the site and finding information.
Click > kzrider.com/index.php?option=com_kunena&...w&catid=13&id=376734
As shown on kawasaki.com, 1980 KZ440-B1 has a return spring (see pic below, #10).
Last edit: 16 Jan 2011 20:25 by Patton.
- nbrider
16 Jan 2011 20:46
your the man, thats what I was lookin' for, and thankfully thats what I ordered.
1983 KZ440 LTD
- nbrider
19 Jan 2011 11:55
Hate to revamp the dead (this topic) but the diagram confirms that that is indeed the spring I need, but it doesnt show where the other end connects to. Not sure where is would pull to, all I know is that it needs to connect to something in the downword direction, to pull the brake back up..
Hmm.
Hmm.
1983 KZ440 LTD
- stonemaster
19 Jan 2011 12:51 - 19 Jan 2011 12:55
www.bikebandit.com/
they have all the parts diagrams
I think what ur pointing to is for brake light switch, a spring is hooked there I THINK
Last edit: 19 Jan 2011 12:55 by stonemaster.
- Kidkawie
- I bleed premix
19 Jan 2011 13:15 - 19 Jan 2011 13:20
IDK what year bike you have, but you can try Bikepics.com. alot of the images there are huge so you can zoom in on an area or DL them to your computer and zoom in on an area. Here's a 1980, that spring is horizontal and hooks somewhere behind the exhaust bracket.
p1.bikepics.com/pics/2008/05/20/bikepics-1295471-full.jpg
Opps, here's a better pic, check the other years too..
p1.bikepics.com/pics/2008/05/20/bikepics-1295469-full.jpg
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
Last edit: 19 Jan 2011 13:20 by Kidkawie.
- Motor Head
19 Jan 2011 14:28
Look for an attachment loop at the swing arm.
- stonemaster
19 Jan 2011 14:38 - 19 Jan 2011 19:15
after looking again those arent the same pedals, I see the brake light attachment now , but the attachment point for the return spring has a hole in the diagram and a stud in the photo
the attachment wouldnt be on the swingarm it would be on the frame
Last edit: 19 Jan 2011 19:15 by stonemaster.
- nbrider
21 Jan 2011 04:02
ill keep checkin around, since there was no spring on it when I bought it im thinking they may hae broken the other tab off, I may just fabricate something in a good position.
1983 KZ440 LTD
- stonemaster
21 Jan 2011 04:07 - 21 Jan 2011 04:09
what year is urs ?, some have coil spring that doesnt operate with a tab
also it may hook to motor mount plate
Last edit: 21 Jan 2011 04:09 by stonemaster.
