Brake rotors
  • customkz1000
  • customkz1000's Avatar Topic Author
Brake rotors
16 Jan 2011 10:09 - 16 Jan 2011 10:19
#422697
I have a question about brake rotors. You see the full rotor and you see the ring type rotor. the ring type is about 2.5 inches wide . Is it as effective?
Last edit: 16 Jan 2011 10:19 by customkz1000. Reason: need pic
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
Re: Brake rotors
16 Jan 2011 10:23 - 16 Jan 2011 10:23
#422700
the larger the diameter the more leverage the rotor has on the wheel.so the diameter matters more than how wide it is.
hth,
Last edit: 16 Jan 2011 10:23 by 531blackbanshee.
  • gane
  • gane's Avatar
Re: Brake rotors
16 Jan 2011 13:00
#422737
Believe what you refer to as a ring rotor is usually called "floating rotor" & its "swept" area is seperate from it's "carrier". They are usually thinner & lighter than 1 piece rotors & don't "bell" (distort) as much w/extreem heat. As Leon says, larger diameter provides better braking & heat dissipation. luck G
[img][/img] 1977 KZ1000A1
  • The Fish
  • The Fish's Avatar
Re: Brake rotors
23 Jan 2011 04:38
#424600
When comparing the old style brake discs (1970's) to the newer style brake discs (1990's and above-generally)there are 2 different style "bands". The "band" is referred to as the area where the brake pads contact the brake disc (also called "swept area").
The 1970's style discs have wide "bands". The wide band discs use the height(top to bottom) of the brake pads to contact the disc to slow the bike. The wide band discs are generally thicker.
The later style narrow "band" discs use the width(front to rear) of the brake pads to contact the disc to slow the bike down. With the narrow band discs, MFG's often use multi-piston calipers with pads that have more surface area than the old wide band discs.
The newer "ring-style(?)" discs are alot lighter and displace heat alot faster than the old thick discs (as pointed out above)
KZ 900= dual 310mm discs Tokico 6 piston calipers
The following user(s) said Thank You: SBK Racer
  • SBK Racer
  • SBK Racer's Avatar
Re: Brake rotors
21 Dec 2012 21:43
#563967
I know this is a very old thread...
But I noticed that "The Fish" log in about 2 weeks ago... :D
I am looking for an upgrade for a 1998 KZ1000P-17 with 18" wheels
What rotors are these? They look like the Ducati SR4 but those are 320mm...
The Calipers are the TLR Hayabusa and older GSXR1K Tokicos?
And, Do you sell those brackets?
Thanks
MOTORCYCLES ARE DANGEROUSLY FUN!!!
A good street rider uses judgment, to avoid situations that require superior skill...
A good track rider uses superior skill, to seek situations that define their judgment...
1998 KZ1000P-17 - 2004 PW80 Pit Bike - 2005 SV650R - 2006 SV650 - 2006 GSXR750 - Soon day BMW SS1000R
Arizona, USA
  • bountyhunter
  • bountyhunter's Avatar
Re: Brake rotors
21 Dec 2012 21:51
#563969
No free lunch. Less rotor mass means they saturate with heat faster which is where they start to fade. The thinner ones also warp much more easily. In the old days (80's) cars had heavy cast iron rotors. Loved them. They cost $16 new, very cheap to make. Never warped.
Now the focus is on squeezing every ounce of weight out and hence the magic of lighter rotors (to save fuel). On cars, they use dual disc "hollow" rotors with air holes and all that crap. Less rotor mass relies on constant airflow to remove the heat.
No free lunch.
