what chain do you run?
- kz1k
- You Cant Fix Stupid!
13 Jan 2011 17:38
i have been podering through the web reading about different chains and companys that sell them. whats your favorite chain company and why? what companys should people stay away from? thanks, Joe
1978 KZ1000A2
- dejavoodo41
Re: what chain do you run?
13 Jan 2011 17:53
I run a RK 530 O-Ring and have close to 30K miles on it and am very pleased with it.
1977 KZ1000A With 1980 KZ1000A MKII engine, Wiseco 1105 kit, Dyna S Ignition, 3 Ohm Dyna Coils, Cams, Mikuni RS34 Carbs, Vance and Hines Pro Pipe with Comp Baffle
New Smyrna Beach, FL
- kz1k
13 Jan 2011 18:04
when i get my sprockets installed, how do i know how long of a chain i need, and where does it tell me that when buying?
1978 KZ1000A2
- dejavoodo41
13 Jan 2011 19:01
If you are replacing stock components you will need an 18 tooth front sprocket 42 tooth rear sprocket and a 110 link chain I believe
Z1E has all of the details here.
www.z1enterprises.com/reference/chain630to530.aspx
- kz1k
13 Jan 2011 19:17
dejavoodo41 wrote:
yeah im far from stock brotha.:blink:If you are replacing stock components you will need an 18 tooth front sprocket 42 tooth rear sprocket and a 110 link chain I believe
1978 KZ1000A2
- DoubleDub
13 Jan 2011 21:05
Pretty sure you'll have to measure the loop from front sprocket to rear and divide by pitch (5/8" for 530) which will give you the number of links. Not sure how much extra you would calculate for stretch/adjustment.
- TomW
- Keep the blue side up.
13 Jan 2011 23:21
I would measure center to center distance from counter shaft to rear axle and double it. Divide by .625 for a 530 chain and add half the number of teeth on each of the sprockets. I THINK this will give yo the number of links needed in the chain. Or call Jeff at Z1E and give him the information and let him figure it out for you.
Tom
Tom
'78 KZ1000B2 LTD stock + Vetter Fairing & luggage
'91 ZG1200B5 Voyager XII, stock
14 Jan 2011 02:58 - 14 Jan 2011 03:14
kz1k wrote:
Where available, a "too short" chain (such as perhaps the old previously removed chain) could be temporarily installed onto the sprockets with ends held together using wire or string.
Measure the space between end links to determine number of additional links needed.
Chain length is usually determined by number of links.
Chain "stretch" is usually determined by linear measurement compared to a given known spec.
An alternative could be measuring linear distance of a string looped over both sprockets (in their installed positions). This linear measurement will likely result in a too long chain, maybe one or two links. Then remove links to fit application.
What's link size of the intended chain?
Last edit: 14 Jan 2011 03:14 by Patton.
- kz1k
14 Jan 2011 04:26
Patton wrote:
ganna use a 530, 17 tooth 5/8" offset in front, and 41 in rear. zx7r swingarm.kz1k wrote:when i get my sprockets installed, how do i know how long of a chain i need, and where does it tell me that when buying?
1978 KZ1000A2
14 Jan 2011 05:02
kz1k wrote:
As suggested by DoubleDub, overall length in inches divided by 5/8 shows number of links in a 530 chain.
- kz1k
14 Jan 2011 05:16
Patton wrote:
cool.kz1k wrote:ganna use a 530, 17 tooth 5/8" offset in front, and 41 in rear. zx7r swingarm.
1978 KZ1000A2
- steell
14 Jan 2011 09:50 - 14 Jan 2011 09:52
I haven't actually tried this, but it should work I think.
Measure the distance between the center of the axle and the center of the output shaft. Double it and divide by 5/8.
Add the teeth of the two sprockets together then divide by two.
Add the first number to the second number and that should be the chain length in links.
Example:
30" center to center equals 60" when doubled, divided by 5/8" equals 96, so that's 96 links.
17 plus 41 equals 58, 58 divided by 2 equals 29.
so 96 links plus 29 links equals 125 links.
Anyone see a problem with the above??
Seems to me like it ought to work, but maybe I missed something.
Example:
Last edit: 14 Jan 2011 09:52 by steell.
