Mirrors
  • Mykuh
  • Mykuh's Avatar Topic Author
Mirrors
02 Jan 2011 14:09 - 02 Jan 2011 19:46
#419772
anyone use bar end mirrors on their drag bars for the kz1000 ? The stock placement of the mirrors I am constantly having to lean or tilt my shoulders to see in the mirrors. Any pictures,suggestions would be much appreciated.
Thanks much !
1978 KZ1000A
Last edit: 02 Jan 2011 19:46 by KZQ.
  • P21
  • P21's Avatar
Re: Mirrors
02 Jan 2011 14:33
#419777
best advice is to turn your head and live another day of riding.
Kawasaki KZ 1000 Police (2002) P21
  • testarossa
  • testarossa's Avatar
Re: Mirrors
02 Jan 2011 16:54 - 02 Jan 2011 16:55
#419791
I have no experience but hear that the bar end mirrors do allow better rear vision. Another option is to use under slung mirrors. That's what I have done on my bike. I did have to make my own mounting brackets, and you have to be cautious about placement so as not to hit the tank. My view to the rear is virtually un-impeded. Click the picture to enlarge.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
Last edit: 02 Jan 2011 16:55 by testarossa.
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
Re: Mirrors
02 Jan 2011 16:57 - 02 Jan 2011 17:00
#419793
Anyway...
Several manufacturers specifically prohibit bar end/underslung mirors, as they do not function/provide the headsup, unimpeded view as reg mirrors...
But I hate reg mirrors too!
Don't buy the cheapo bar end mirrors, they suck bad.
CRG makes a nice rigid product, and others. Look for a good solid connector/weight + they should cost a fair bit.
BOL
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 02 Jan 2011 17:00 by TeK9iNe.
  • stonemaster
  • stonemaster's Avatar
Re: Mirrors
02 Jan 2011 17:24
#419800
Mirrors :blink: WHY ????
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
Re: Mirrors
03 Jan 2011 13:59
#419902
i have bar end mirrors and am very happy with the vision that i can get with them.way better vision than stock because,like you mentioned i don't have to move to see outta them.i bought the ones everyone said not to because they are screwed together from the inside then the glass is glued in.i figured for the price difference(100 bucks or so depending)that i could gamble.before i installed mine i sat them face down on a padded bar stool and used a center punch to stake the screws so that hopefully they would not loosen up.
hth,
  • gengomerpyle
  • gengomerpyle's Avatar
Re: Mirrors
03 Jan 2011 16:04
#419923
hth,
great looking bike
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
  • MFolks
  • MFolks's Avatar
Re: Mirrors
03 Jan 2011 16:25
#419925
Maybe some Loctite #242 might work, it's not the type requiring 300 degree heat to loosen like the red type does.
Thread Locking Compounds
Loctite #222MS PURPLE, low strength thread locker
For screws under ¼”.
Loctite #242 BLUE, Medium strength thread locker
For ¼” to ¾” bolts.
Loctite # 262 RED, High strength thread locker permanent
For up to ¾” bolts (can be loosened by 300 F heat).
Loctite #271 RED, High strength thread locker for sealing plugs, nuts and bolts (can be loosened by 300 F heat).
Loctite # 272 RED, High strength, high temperature(450 F) thread locker.
Loctite #565 Pipe Joint Compound.
Loctite #567 High Temperature Pipe Joint Compound
Loctite #6749 Primer
Loctite #515 Flange & Gasket Sealers
Permatex # 24310 Low strength thread locker, PURPLE, fasteners under ¼” diameter.
Permatex # 22210 Medium/high strength thread locker, BLUE, ¼” to ¾” fasteners, surface insensitive (can be used on oily fasteners).
Permatex # 24210 Medium strength thread locker, BLUE, ¼” to ¾” fasteners.
Permatex # 27710 High strength thread locker, RED, 3/8” to 1 inch fasteners, may require heat for removal.
Permatex # 26210 Permanent strength thread locker. RED, 3/8” to 1 inch fasteners, will require heat for removal.
Engine Chemicals
Mopar Combustion Chamber Cleaner # 04318001. Designed to remove carbon from combustion chambers & valves.
www.amazon.com/Yamaha-Ring-Additive-32oz...-32-00/dp/B002GUCLH2 (Yamaha Ring Free)
Yamaha Combustion Chamber Cleaner ACC110008200
Features: Laboratory and field-tested blend of chemicals to remove power-robbing deposits that accumulate in gasoline engines.
Kleen flo Combustion Chamber Cleaner
STOCK No823
Purges carbon, gum, varnish, sludge from internal parts. Helps increase gas mileage. Oxygen sensor and catalytic converter safe. Improves engine work. Can be used in exhaust catalyst system.
Yamaha Carb Cleaner # ACC-CARBC-LE-NR
www.barsproducts.com/E10L.htm
Seafoam oil and gasoline additive.
Berryman’s B-12 Gasoline additive.
Engine Gasket Sealers/Gasket Makers
www.bikebandit.com/threebond-engine-silicone-gasket-1211
  • Old Man Rock
  • Old Man Rock's Avatar
Re: Mirrors
04 Jan 2011 05:18
#420006
Get the models that are designed with Anti-Vibration dampening and convex mirrors... Rotated slightly forward and up, no issues with blocked vision over arms.
You'll be surprised how heavy these little mirrors are with the weights in them....(Anti_vibration)
Benefits:
1) Very stable vision...
2) Less hand fatigue...
3) Easily 1-2 lane outside coverage...
4) Nice looks...
Here's the ones I'm using found at cyclegear.com
www.cyclegear.com/spgm.cfm?L1=&L2=&L3=&L4=&item=PRC_MBM12BLK_G
Some others:
www.speedmotoco.com/ProductDetails.asp?ProductCode=smc600700
www.motorcycle-superstore.com/1/4/68/275...aspx?WT.ac=SLIsearch
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • 531blackbanshee
  • Vendor
  • Vendor
Re: Mirrors
04 Jan 2011 06:34 - 04 Jan 2011 06:35
#420018
thanks for the compliment gengomerpyle.
me and omr got the same mirrors :laugh: .
the convex does make a big difference,although stuff way off is pretty small.
Last edit: 04 Jan 2011 06:35 by 531blackbanshee.
  • steell
  • steell's Avatar
Re: Mirrors
04 Jan 2011 10:10
#420032
So you can see the red and blue lights mounted on the car behind you flashing :laugh:
  • lewisj
  • lewisj's Avatar
Re: Mirrors
04 Jan 2011 10:32
#420037
I have recently added the CRG bar end mirrors and love them. Good vision(no elbows or shoulders)rock solid, noo vibration. Worth the money.
Jim
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
Vance&Hines header/ exhaust
29mm smoothbores w/pods
ZR7S 41mm Front Forks with 17" wheels
