kz1000 front fork rebuild ???
  • BSKZ650
  • BSKZ650's Avatar Topic Author
01 Jan 2011 06:17
#419576
took the front shocks apart, and in lookng at the diagram, looks like soemthing might be missing. if you look at part munber 19, the top of the shaft appears to have some type of seal ring on it, but it shows no part number fo it.
The FSM identifies it as number 4 and lists it as a piston ring.
The whole question is, what is supposed to be there if anything, I have a groove with nothing in it.
any ideas?
www.bikebandit.com/houseofmotorcycles/19...le-1000-ltd-kz1000b1
77 ltd1000, current rider
76 kz900, just waiting
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Re: kz1000 front fork rebuild ???
01 Jan 2011 07:02
#419583
Hello Bobby...I need some clarification...I think I understand what you are asking, but your link has already expired. What page on the FSM are you referring (I have it so I can take a peek)? What is the part Kawasaki number of the larger piece that the 'piston ring' fits on? I think it is a bushing but we'll see.
Michael
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • BSKZ650
01 Jan 2011 07:46
#419588
in my FSM its on page 185, maintenance - chassis
thanks for your help
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
01 Jan 2011 08:38
#419590
What is supposed to be there is a non-metallic, thick, split, ring. It fits loosely, spins freely, is probably a fiber-based compound, and probably aids in retention of fork oil as the oil is forced up and down the inner fork tube. Unfortunately, it does not, as you suspected, come as a separate part...you have to acquire the entire inner fork tube. If I recall correctly, others have run into this problem and ended up making their own, running the front end w/out it, or substituting from another bike (there are other model bikes that use the the same sort of technology...I just don't recall which). The set of 1977 inner fork tubes I have are in good shape and I think I could remove these fiber 'piston rings' w/out damaging them. Who knows, you might find them on eBay (not mine, though :) )
Michael
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • BSKZ650
01 Jan 2011 18:11
#419651
Michael, you were correct, the left fork had the fiber ring on it and the right did not, so I went to NAPA, and bought a o ring and installed it.
I am now kind of having second thoughts since both sides do not match, but I guess I will ride it and see what happens.
On another note, seems to me with oil only in the shocks, and working the tube up and down you would feel some resistance, but I really didnt feel any, seems to me that its working off the spring only.
is there still a problem with the shocks? any thoughts would be appreciated
Bobby
  • testarossa
  • testarossa's Avatar
01 Jan 2011 21:47
#419683
It's possible that the o-ring may absorb some oil and swell. It may add some amount of stiction to your fork. I'm not sure how much difference it will make, but if the fork starts to become stiff, then I would suspect your o-ring is the culprit.
You may try and call Race Tech, they do sell all kinds of small rebuild parts for motorcycle suspension.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
02 Jan 2011 01:19
#419700
I'm with testarossa on this...I don't know how much of an effect the o-ring will have...as long as the fit on the inside of the outer fork tube is not tight, then it might mimic the effect of the fiber ring. There is a fair amount of play with the fiber ring and as long as the o-ring doesn't swell up and completely block oil movement (it needs to impede it, not block it) you might be fine.
Michael
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • testarossa
02 Jan 2011 01:33
#419701
Is this the all Houston Metro Area thread? Happy New Year boys.
2004 ZX-10R
Angola, IN
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
02 Jan 2011 02:26
#419703
Yep...strange, but true. :)
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • BSKZ650
02 Jan 2011 05:10
#419712
I didnt think about the o ring swelling, good point, I am going to look for the correct fiber part, prob goning to look for a complete good set of forks to rebuild and replace the ones I have.
Thanks for all the help !!
Bobby
  • P21
  • P21's Avatar
02 Jan 2011 05:36
#419713
well he said it was a split ring
and a o-ring is not a split ring?
alota dif
take o-ring out.
Kawasaki KZ 1000 Police (2002) P21
