Rear brake rotor size
  • mheer
  • mheer's Avatar Topic Author
29 Dec 2010 14:03
#419170
What is the diameter of the rear brake rotor on a KZ1000 B3 (KZ1000 LTD 1979)? Mine needs to be replaced. I have ordered two off of eBay and both are a larger diameter than the one on the bike. I don't know if the one on the bike is original.
Please help!
Mike
  • MFolks
  • MFolks's Avatar
Re: Rear brake rotor size
29 Dec 2010 16:33
#419204
Contact www.z1enterprises.com for good information.
Also EBC makes replacement disc's.
  • Kapahulu
  • Kapahulu's Avatar
30 Dec 2010 12:42
#419366
I haven't measured but also noted that my '79 LTD rear disc is a little smaller that what was on the '77 and 78 "A" models. I have wheels from both those bikes sitting around waiting to be used.
If you get the brake caliper holder off an earlier model, it should have the correct clearance to accept the larger disc.
2strokeworld.com
  • MFolks
  • MFolks's Avatar
30 Dec 2010 12:50
#419370
Another repair to think about is to have the disc rotor built up with a metal spray and then machined to the correct thickness. Almost any metal can be vaporized and then sprayed on parts.
Here's some examples:
www.flamesprayinc.com/companyinfo.htm
www.birdsperformancecoatings.com/
I'd call around the machine shops getting prices for this.
  • andy9802gt
  • andy9802gt's Avatar
  • If it tastes that good, eat it yourself.
30 Dec 2010 16:54
#419405
the rear on my '78 is 10 15/16" the fronts are like 11 7/16" if that helps and it's just off the top of my head
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
  • mheer
31 Dec 2010 10:07
#419487
Thanks
Mike
