quality machine shop
  • kz1k
  • kz1k's Avatar Topic Author
  • You Cant Fix Stupid!
28 Dec 2010 09:59
#418890
hey guys. i need a sleeve made for my swingarm. i called a local machine shop and was quoted 230 bucks to make a sleeve for my bike that has a the OD of my zx sleeve and the ID of my kz bolt. i would like to send my zx sleeve to a shop and have them make what i need. any suggestions? thanks
1978 KZ1000A2
  • kz1k
Re: quality machine shop
28 Dec 2010 11:01
#418896
i did find 6061 aluminum solid thats 12" long, and 1 3/8" OD. could i drill the 5/8" hole in a lathe and cut down to length? its 10 bucks for a 12" piece.
1978 KZ1000A2
  • P21
  • P21's Avatar
28 Dec 2010 11:13
#418898
how long is this sleeve or bushing?
Kawasaki KZ 1000 Police (2002) P21
  • P21
  • P21's Avatar
28 Dec 2010 11:17
#418899
is this 3-parts
bushing then sleeve then another bushing
  • kz1k
28 Dec 2010 11:18 - 28 Dec 2010 11:23
#418900
8 13/16" long. i can cut holes in the frame to accept the zx pivot bolt.....not sure yet. i would have to cut a 1 1/4" hole in one side and a 1" hole on the other side of the frame. i may just go that route. ill have to do what adam did and weld a plate over my pivot hole so i can have a center for the hole saw. but then i need bushings made.
1978 KZ1000A2
Last edit: 28 Dec 2010 11:23 by kz1k.
  • P21
  • P21's Avatar
28 Dec 2010 11:23
#418903
if you have lathe make OD what ever you need then drill the bushing for the bolt you need, dont drill frame holes
  • stonemaster
  • stonemaster's Avatar
28 Dec 2010 11:24
#418904
$230 jeez !! too bad ur not closer to where i live, my guy is VERY REASONABLE and damn good too) if u cant locate someone Ill check and see for ya, it would be next week before I could get over there.
  • P21
  • P21's Avatar
28 Dec 2010 11:25
#418905
swing arm mod?
  • P21
  • P21's Avatar
28 Dec 2010 11:28
#418906
230.00
seems this guy what to pay off his machinery?
dude is a F^^king rip off
  • kz1k
28 Dec 2010 11:33 - 28 Dec 2010 11:34
#418907
yeah drilling the holes in the frame would create more work.
the "lathe" i have access too is basically a machine you put your material in and the material spins...the drill bit does not. this machine is ancient and this is just about all you could do with it.
swingarm mod yes....rip off...yes. lol
1978 KZ1000A2
Last edit: 28 Dec 2010 11:34 by kz1k.
  • kz1k
28 Dec 2010 11:37
#418908
the only issue i have is on the pivot sleeves there is about 1.5" on each end that seems like it has a stainless cap for the bearings to roll on. could i remove the ones on the ones on the zx and press them on my fabricated sleeve?
1978 KZ1000A2
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
28 Dec 2010 12:41
#418915
joe,
i can do the machine work you need.
i have done work for several members,and am experienced and reasonable.
lemme know if i can help,
