gas cap seal
  • hocbj23
  • hocbj23's Avatar Topic Author
gas cap seal
24 Dec 2010 07:08
#418418
82 KZ1000 with a problem with the gas cap seal (I think).When locking the cap,after it clicks in the closed position,there still appears to be gap between cap and surface of filler neck.Cap is correct for the tank,I have replaced the o rings on the mounting screws,filler neck is clean inside and out,cap has the correct gasket but it appears to be original.Is the gap normal? If not,any way to adjust the cap?I have had the cap apart,cleaned and lubed it and it works fine-just the gap issue.Thanks.bj
  • stonemaster
  • stonemaster's Avatar
Re: gas cap seal
24 Dec 2010 16:06
#418478
when ur cap is open press down and see if it springs back if not the spring between the seal and the cover is broke
  • hocbj23
Re: gas cap seal
24 Dec 2010 16:34
#418485
spring is fine.bj
Re: gas cap seal
24 Dec 2010 18:25 - 24 Dec 2010 18:26
#418497
hocbj23 wrote:
82 KZ1000 with a problem with the gas cap seal...have replaced the o rings on the mounting screws...had the cap apart,cleaned and lubed...
To confirm --- when reassembling, the o-rings fit against the tank.
gasket
www.z1enterprises.com/detail.aspx?ID=1906
Good Fortune! :)
Last edit: 24 Dec 2010 18:26 by Patton.
  • hocbj23
Re: gas cap seal
24 Dec 2010 19:26
#418507
Yessir.I checked this illustration to be sure I had it right.I have ordered a new gasket as I think thats the only part that would affect sealing properly.Thanks Patton.Happy Holidays.bj
