83 LTD 750 belt drive swap to 83 kz 1000P?
  • Marine Dad
  • Marine Dad's Avatar Topic Author
18 Dec 2010 09:43
#417579
Hi guys,
New to site with my retired KZ1000 cop bike.
Swaping over to new tires and brakes.
So while i'm in there thought of switching to belt drive.
Will this idea work?
Anyone tried this?
Any info is good.
  • Nebr_Rex
  • Nebr_Rex's Avatar
Re: 83 LTD 750 belt drive swap to 83 kz 1000P?
18 Dec 2010 09:55
#417582
spockets and pulleys might swap out but the drive belt length would require some research
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • Marine Dad
18 Dec 2010 10:01
#417583
That would be OK with me.
I plan on just low impact cruiseing.
Not drag raceing.
you know the best used parts dealer to find a set?
  • Nebr_Rex
  • Nebr_Rex's Avatar
18 Dec 2010 10:35
#417596
no,you'll have to do a search
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
  • TexasKZ
  • TexasKZ's Avatar
18 Dec 2010 10:46
#417608
Be prepared for some sticker shock. I had an 83 belt-drive 750 LTD that needed a new belt and pulleys. The price back in the day was several times the cost of converting to chain. :ohmy: Guess which way I went...
If you do pursue this with used parts, look carefully at pulleys for wear. It is not always as obvious as one might think. The lands and groves need to have fairly sharp, well-defined edges all the way across. Also be aware that you will likely need to mod or fab a new belt guard and there may be clearance issues at the frame and countershaft sprocket cover. Then there is the likelihood that the countershafts have different diameters and number of grooves, the bolt pattern on the cush drive may be different, etc....
Let us know how it comes out.
  • steell
  • steell's Avatar
18 Dec 2010 16:09
#417645
If you're anywhere near Little Rock AR I can tell you where there's a 83 KZ750 Belt for $350.
Might be the cheapest way to get parts, I'd have bought it except for the lack of title.
  • Marine Dad
19 Dec 2010 09:44
#417725
Thanks
Very good info on what to expect.
The best thing is I have all winter here in Oregon to
Work on the bike before riding weather hits.
(and a dry,warm shop!)
If it looks way to spendy I will stay with chain.
  • Marine Dad
19 Dec 2010 21:27
#417826
Texas KZ,
When you switched from belt to chain on your ltd750 what parts did you use?
Did the sprockets just interchange from a reg KZ?
