1979 kz1000 st
- 66tbird
1979 kz1000 st
18 Dec 2010 06:17
Hello , I have a 1979 kz1000 st and I want to put 12" shocks on her . Can someone tell me what different shock options do I have [brand name , part #] so I can lower her . I don't want to cut my seat , I like the look.
- Nebr_Rex
Re: 1979 kz1000 st
18 Dec 2010 07:29 - 18 Dec 2010 11:33
progressive,works,ohlins
What is your weight,inseam?
The st is a tall and heavy bike.
I like a 13 in. shock with a softer spring.
Ride comfort and handling is improved.
With a stiffer spring the shock is near full extention most of the time and the tire will lose contact with the road.
But you can not go to soft or you will bottom out,you will need stiffer compression dampning on the shock.
Also you can raise the forks about an in.
Only one side at a time,tighten that side back up to factory specs,then the other side
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
Last edit: 18 Dec 2010 11:33 by Nebr_Rex.
- 66tbird
- Nebr_Rex
Re: 1979 kz1000 st
18 Dec 2010 16:06
66tbird wrote:
That about the same as mine.
I have good results with progressive series 12 13" shocks and the 90/130 springs.
If need be preload can be increased with the adjusters.
Progressive also makes an 11.5" shock but it takes a shorter spring.
I'm 5'11" 225 lb. and my inseam is 30 .
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- 66tbird
Re: 1979 kz1000 st
19 Dec 2010 05:39
Thankyou vary mutch Nebr_Rex. I was looking at your picture and it looks like you cut the seat foam . Is that the stock seat cover ?
- Nebr_Rex
Re: 1979 kz1000 st
19 Dec 2010 05:57
fibrglass seat pan
unknow origin,came with another st
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
