76- KZ900- Modern Front End Update?
- Gringo
14 Dec 2010 13:08
Hey Folks,
I'm interested to hear suggestions towards updating my KZ900 front end. Forks, clamps and wheels with a late model sport bike type set up to give her a more modern suspension set up and look.
If any of you have done this I would greatly appreciate suggestions as to what parts will best fit to get the job done so that I can map out the refit and start on my eBay quest for parts to target.
Thanks!!
Thanks!!
- elseed
Re: 76- KZ900- Modern Front End Update?
14 Dec 2010 14:13 - 14 Dec 2010 14:14
I used the entire front off a '89 ZX7 (ZXR750) on my '75 Z1. Worked as a bolt-on for that model by only adding a couple bearing shims to Z1 replacement tapered bearings.
I think the '76 frame was strengthened somewhat - not sure of '75 to '76 matchup.
Galaxian started a thread about this particular route (and there are some others out there). See it on the archive: www.kzrider.com/archive/viewthread.php?tid=29959
Other issues to consider:
- Whatcha going to do for a guage cluster, especially a speedo? I made a custom cable for '89 front wheel to original '75 speedo. There was a lot of little fabrication and fooling around to get cluster, headlight, brake lines, etc. all squared away.
- Whatcha going to do for handlebars? Clip-ons were low, uncomfortable, and bumped the tank. I switched to a superbike bar conversion kit - adds handlebar risers to top triple.
- Whatcha going to do for a rear end? Leave the original KZ wheel and swingarm? 17" up front might be odd stance. I swapped to '90 ZX11 wheels and disc brakes at both ends. Endless complications but I like the results. (ZX11 wheels fit the ZX7 forks just fine, btw).
Typical thing: People can tell you what they did, but can't tell you if your plan will work unless fabrication is no object (time and money!).
'75 Z1B with mods
Last edit: 14 Dec 2010 14:14 by elseed.
- larrycavan
14 Dec 2010 14:28
GSXR forks seem to be the easiest to fit up and have good length.
I went ZX7 route. Was considerable work.
