larger tire
  • kz1k
  • kz1k's Avatar Topic Author
  • You Cant Fix Stupid!
larger tire
13 Dec 2010 07:21 - 13 Dec 2010 07:43
#416719
i was wondering what swing arms would either bolt on or need minor fabrication to install on my frame. im just looking to use a larger tire and slightly stretch the rear. ill be doing some searching, but while i am throw out some ideas.
how about the gs1100? it seems ly kz swingarm mounting spread is 9.25".
1978 KZ1000A2
Last edit: 13 Dec 2010 07:43 by kz1k.
  • kz1k
Re: larger tire
13 Dec 2010 08:09
#416721
ok i found a 05 hiyabusa swingarm that with bushings and all outside measures just under 9.25", my opening is 9.25". that should work right?
1978 KZ1000A2
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
Re: larger tire
13 Dec 2010 09:38
#416733
it seems like the bracing on the busa arm gets in the way of the frame a little,but the brace could be removed or altered to work.the tl 1000 arm is also a good swap.check out roynor's build thread he used a tl swinger.
  • kz1k
Re: larger tire
13 Dec 2010 10:14 - 13 Dec 2010 10:15
#416735
which year tl 1000 swing arm? the newer the model the shape changes. whats the biggest tire that fits them? could i put a 180 on there?
1978 KZ1000A2
Last edit: 13 Dec 2010 10:15 by kz1k.
  • kz1k
Re: larger tire
13 Dec 2010 10:40
#416738
does the tl1000r fit right in? if so it holds a 190 tire.
1978 KZ1000A2
  • kz1k
Re: larger tire
13 Dec 2010 11:35 - 13 Dec 2010 11:36
#416749
bb, in roynors thread he decided noy to use the tl...instead he went with the busa arm offset.
kzrider.com/index.php?option=com_kunena&...imitstart=320#256772
1978 KZ1000A2
Last edit: 13 Dec 2010 11:36 by kz1k.
  • 531blackbanshee
  • Vendor
  • Vendor
Re: larger tire
13 Dec 2010 11:48 - 13 Dec 2010 14:14
#416750
i don't know what years tl man.
here is the one i built.i am more of a roll yer own kinda guy,:laugh: .
this is the one on my z1r that uses an r1 rear wheel and brembo brake.
Last edit: 13 Dec 2010 14:14 by 531blackbanshee.
  • 531blackbanshee
  • Vendor
  • Vendor
Re: larger tire
13 Dec 2010 11:53 - 13 Dec 2010 11:58
#416751
a 200 fits in there with a 520 x-ring and 3/8's offset counter shaft sprocket.
here it has a 190,
p.s.just posted here bc the pics wouldn't show in the pm.
Last edit: 13 Dec 2010 11:58 by 531blackbanshee.
  • kz1k
Re: larger tire
13 Dec 2010 14:02
#416773
anyone used a gsxr rear setup?
1978 KZ1000A2
  • 531blackbanshee
  • Vendor
  • Vendor
Re: larger tire
13 Dec 2010 14:11
#416777
the older gixxers without under or overbrace are what you are looking for.
late 80's early 90's i think.
hth,
  • testarossa
  • testarossa's Avatar
Re: larger tire
13 Dec 2010 14:18
#416778
Mine is a 1995 GSXR 750 with a massive overbrace. You'll need to go earlier than that or cut the brace off if you plan on running twin shocks.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • kz1k
Re: larger tire
13 Dec 2010 14:23
#416780
i have a kid that wants to sell me a 2006 gsxr rear shock, swing arm, rim, rotor, and caliper, plus all hardware to rim and caliper for 200 bucks.
1978 KZ1000A2
