larger tire
- kz1k
- You Cant Fix Stupid!
larger tire
13 Dec 2010 07:21 - 13 Dec 2010 07:43
i was wondering what swing arms would either bolt on or need minor fabrication to install on my frame. im just looking to use a larger tire and slightly stretch the rear. ill be doing some searching, but while i am throw out some ideas.
how about the gs1100? it seems ly kz swingarm mounting spread is 9.25".
1978 KZ1000A2
Last edit: 13 Dec 2010 07:43 by kz1k.
- kz1k
Re: larger tire
13 Dec 2010 08:09
ok i found a 05 hiyabusa swingarm that with bushings and all outside measures just under 9.25", my opening is 9.25". that should work right?
1978 KZ1000A2
Re: larger tire
13 Dec 2010 09:38
it seems like the bracing on the busa arm gets in the way of the frame a little,but the brace could be removed or altered to work.the tl 1000 arm is also a good swap.check out roynor's build thread he used a tl swinger.
- kz1k
Re: larger tire
13 Dec 2010 10:14 - 13 Dec 2010 10:15
which year tl 1000 swing arm? the newer the model the shape changes. whats the biggest tire that fits them? could i put a 180 on there?
1978 KZ1000A2
Last edit: 13 Dec 2010 10:15 by kz1k.
- kz1k
Re: larger tire
13 Dec 2010 10:40
does the tl1000r fit right in? if so it holds a 190 tire.
1978 KZ1000A2
- kz1k
Re: larger tire
13 Dec 2010 11:35 - 13 Dec 2010 11:36
531blackbanshee wrote:
kzrider.com/index.php?option=com_kunena&...imitstart=320#256772
bb, in roynors thread he decided noy to use the tl...instead he went with the busa arm offset.it seems like the bracing on the busa arm gets in the way of the frame a little,but the brace could be removed or altered to work.the tl 1000 arm is also a good swap.check out roynor's build thread he used a tl swinger.
1978 KZ1000A2
Last edit: 13 Dec 2010 11:36 by kz1k.
Re: larger tire
13 Dec 2010 11:48 - 13 Dec 2010 14:14
i don't know what years tl man.
here is the one i built.i am more of a roll yer own kinda guy,:laugh: .
this is the one on my z1r that uses an r1 rear wheel and brembo brake.
Last edit: 13 Dec 2010 14:14 by 531blackbanshee.
Re: larger tire
13 Dec 2010 11:53 - 13 Dec 2010 11:58
a 200 fits in there with a 520 x-ring and 3/8's offset counter shaft sprocket.
here it has a 190,
p.s.just posted here bc the pics wouldn't show in the pm.
here it has a 190,
Last edit: 13 Dec 2010 11:58 by 531blackbanshee.
- kz1k
Re: larger tire
13 Dec 2010 14:02
anyone used a gsxr rear setup?
1978 KZ1000A2
Re: larger tire
13 Dec 2010 14:11
the older gixxers without under or overbrace are what you are looking for.
late 80's early 90's i think.
hth,
hth,
- testarossa
Re: larger tire
13 Dec 2010 14:18
Mine is a 1995 GSXR 750 with a massive overbrace. You'll need to go earlier than that or cut the brace off if you plan on running twin shocks.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
- kz1k
Re: larger tire
13 Dec 2010 14:23
i have a kid that wants to sell me a 2006 gsxr rear shock, swing arm, rim, rotor, and caliper, plus all hardware to rim and caliper for 200 bucks.
1978 KZ1000A2
