Shock Bushings
  • letthegoodtimesroll
  • letthegoodtimesroll's Avatar Topic Author
Shock Bushings
21 Apr 2006 16:27
#41513
I purchased a set of harley shocks over the winter and I am almost ready to put the frame components back together but the bushings with metal sleeves on the new shocks will not fit over the mounting stud. Do I need to just take out the metal sleeve in the new shocks or do I need to swap the bushings from the original shocks to the new ones?
1977 KZ650C1, Kerker Header, Dyna ignition and coils, GPZ 750 oil pan and cooler
  • neilage66
  • neilage66's Avatar
Re: Shock Bushings
21 Apr 2006 17:03
#41523
Do whatever you need to do in order to have a metal bushing/spacer/ring.....over/around the mounting stud. Metal to metal is preferred as opposed to rubber to metal. Worse case scenario, you'll have to do a complete bushing swap OR purchase a new bushing kit of the universal variety. Good luck!
  • Scotty355
  • Scotty355's Avatar
Re: Shock Bushings
22 Apr 2006 05:20
#41615
I am doing the same thing with the harley shocks except I am just going to drill the harley bushings out to fit the post.
Re: Shock Bushings
22 Apr 2006 05:27
#41617
That is kind of the direction I was going. What is the drill bit size you need?
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
Re: Shock Bushings
22 Apr 2006 07:33
#41635
Do you have a lathe with a three jaw chuck? It's kind of tough to drill a hole in a small round piece if steel using a regular vice.
Good Luck
BIll
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
  • hwms
  • hwms's Avatar
Re: Shock Bushings
22 Apr 2006 09:39
#41648
If only a small amount of material needs to be removed I would suggest the use of a reamer instead of a drill bit.
  • JMKZHI
  • JMKZHI's Avatar
Re: .
22 Apr 2006 09:47 - 03 Dec 2008 17:42
#41649
del
Last edit: 03 Dec 2008 17:42 by JMKZHI.
  • Shoe48
  • Shoe48's Avatar
  • Live each day as it is your last
Re: Shock Bushings
22 Apr 2006 19:40
#41746
I have in the past Pushed out the old bushings in a vise with a couple of Sockets, Then used the old bushings from the shocks that fit ,, Not sure this will work for you as I not familar with HD shocks ;) :)
