front sprocket
- hypnohio
front sprocket
29 Nov 2010 14:09
Any hints on removing a front sprocket without the chain on? that sucker's tight, and I can't figure out how to hold it to remove the nut. Is holding it with the chain the only option? thanks.
1982 KZ440 LTD
2003 EN500 C
2006 Virago 250
2003 EN500 C
2006 Virago 250
- TerryK
Re: front sprocket
29 Nov 2010 14:57
Impact gun with the chain on, or you can make a sprocket holder with a short piece of chain, a pair of vice grips, a welder and your imagination.
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
