Rebuilding a spoke wheel - truing stand
- Topper
25 Nov 2010 09:43
I'm considering rebuilding the front spoke wheel on my '88 KZ305. I found a
great article
on this from web bike world, but there's one piece I need more info on.
I need some ideas about how to rig up a truing stand. I can't weld so I imagine I would need to set up some means of holding the axle on a workshop table or something. The article, which is otherwise quite thorough, says almost nothing about this.
Does anyone have any pictures of their own truing stands they could share?
Thanks!
Thanks!
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
1979 KZ750 Twin
Re: Rebuilding a spoke wheel - truing stand
25 Nov 2010 10:12 - 25 Nov 2010 10:13
Topper wrote:
Here's one, courtesy of Kidkawie, in the following earlier thread:
Click here > kzrider.com/index.php?option=com_kunena&...d=5&id=402636#404166
[Click on image to enlarge view.]
I'm considering rebuilding the front spoke wheel on my '88 KZ305. I found a great article on this from web bike world, but there's one piece I need more info on.
Thanks!
Last edit: 25 Nov 2010 10:13 by Patton.
- Injected
25 Nov 2010 19:18
I just re-laced and trued these wheels for a guy - 63 Honda C200... they were really small hubs so I was able to get away with my bicycle wheel stand.
1978 KZ650B2 modified project
- Injected
25 Nov 2010 19:20 - 25 Nov 2010 19:25
I designed this combo truing/balancing stand to do larger wheels - I already have the steel... just have to get it welded... total investment = $9
Instead of steel tubing you could use 2x2 wood... you really don't have to pin down the axles unless your really wailing on the nipples... but at that point you should back off because they are probably "too" tight.
Last edit: 25 Nov 2010 19:25 by Injected.
- Sandy
- Fly High,Tony
25 Nov 2010 22:00
You could always just mount the rim to the forks where it belongs,and true it there.
1977 KZ1000 A-1
- stonemaster
26 Nov 2010 01:24
check this link out,
xlforum.net/vbportal/forums/showthread.p...omemade+tools&page=2
there is a really nice homemade stand or two in this thread, and i mean NICE... I'll be using this one when the time comes
- Kapahulu
26 Nov 2010 09:42
Sandy wrote:
THAT is an interesting idea! I have an extra set of forks and a triple clamp. Figure out way to clamp them to my work bench (an old dresser) and there we go.You could always just mount the rim to the forks where it belongs,and true it there.
2strokeworld.com
2strokeworld.com
- Topper
26 Nov 2010 09:52
I don't have a great work space that will fit the whole bike so without an extra set of forks, I'll need some sort of stand. Some of these examples look pretty easy to build. Thanks for the examples.
1979 KZ750 Twin
1979 KZ750 Twin
- fixer5000
26 Nov 2010 12:57
i used my weight bench lol just clamped the wheel and axle to that.. set up my indicator and went at it
1978 kz650b pretty much stock
massachusetts
massachusetts
- Polar_Bus
29 Nov 2010 14:24
I've never had the opportunitity to lace wheels on a road bike, but I have done several dirtbike wheels, and I don't bother with a truing stand. I use the wheel's axle clamped verticle in a vice, slide the wheel over the axle and use a dial indicator. Works fine for me. Able to true wheels within .015" axial and radial runout
Bikes:
'84 GPz1100
'06 HD Fatboy
'84 GPz1100
'06 HD Fatboy
- Topper
29 Nov 2010 15:37
I hadn't thought about doing it vertically. That's an interesting idea.
1979 KZ750 Twin
1979 KZ750 Twin
