master cylinder disassembly help
  • rf56
  • rf56's Avatar Topic Author
21 Nov 2010 15:48
#413707
Have searched the forum for this info but can't seem to find it. I have a 1980 kz550 A-1 with single front caliper. Want to take apart the m/c but cant figure it out. Has the white "liner" with the cutouts holding it all in. Is a special tool required? Have shop manual and haynes type but they don't give info on disassembly. Thanks
  • MFolks
  • MFolks's Avatar
Re: master cylinder disassembly help
21 Nov 2010 15:59
#413711
I Have a 1982 GPz1100 B2 with(I believe) a similar setup. I turned the liner with needlenose pliers and then pulled it out of the master cylinder. Check your's for a spring clip or snap ring.
  • rf56
21 Nov 2010 16:10
#413713
thanks brother, thought thats how it might work but wanted a second opinion first.
  • rf56
21 Nov 2010 17:01 - 21 Nov 2010 17:03
#413717
Well got the white liner thing out. Thought that held everything in. I don't see a snap ring unless it's behind the rubber dustcover. Is that it?
Last edit: 21 Nov 2010 17:03 by rf56.
  • texasfisherdude
  • texasfisherdude's Avatar
  • 2 old 2 fat dont care
21 Nov 2010 17:48
#413721
mine was stuck and I pushed the plunger in with my finger a few times and it came out
Life's to short to drink cheap beer
1980 LTD 1000
21 Nov 2010 21:21
#413754
If needed, here's the diagram from kawasaki.com ---
Good Fortune! :)
