KZ900 rear wheel on KZ1000
- 55fbomb
19 Nov 2010 18:29
Will the sprocket carrier from my 1000 wheel fit in the 900 hub? i want to change my rear wheel over to a drum setup and found a wheel but it has no sprocket carrier. just wondered if they are the same or if i need a 900 one. thanks.
1974 CB750
1975 CB750
197? CB750 mutt
1977 KZ1000
1975 CB750
197? CB750 mutt
1977 KZ1000
- Jeff.Saunders
Re: KZ900 rear wheel on KZ1000
19 Nov 2010 19:13
They are different.
Are you changing swing arms at the same time? The brake torque bars mount differently.
- 55fbomb
19 Nov 2010 19:19
Yeah, im swappin to a GS arm so the mount will have to be flipped to the bottom. my stock disc setup sucks, not sure if mine just needs rebuilt or they are all kinda weak but i found a good price on a wide rear wheel but its a 900 hub. i guess i will be looking for a 900 sprocket carrier too. and figuring out a linkage to run the drum. thanks.
1974 CB750
1975 CB750
197? CB750 mutt
1977 KZ1000
1975 CB750
197? CB750 mutt
1977 KZ1000
19 Nov 2010 20:41
I don't use the rear brake very often, but I'm pretty sure if you think the disc setup is weak, you're gonna hate that drum.
- z1kzonly
19 Nov 2010 22:29
55fbomb wrote:
Hey Billy, Hows Capt. Amer.?
Yes your disc probally did not work right.
The drum works fine for street use. If the drum lining is not wore out.
Make up some threaded rod with heim joints.
Parts are easy to find on ebay for the drum wheel.
Here is what I did for a drum KZ900
20 Nov 2010 03:34
z1kzonly wrote:
Clean and handsome.
Wondering about lever arm angle.
[Click on image to enlarge view.]
Clean and handsome.
- 55fbomb
20 Nov 2010 06:02
i messed around a little bit with the rear disc and everything seems to be in working order, it just doesnt work very good, seems to have a lot less stopping power than the drums on my CB750s, but mine are a bit lighter than stock too, so that might account for something. i do like the heim joints, that looks real clean man.
1974 CB750
1975 CB750
197? CB750 mutt
1977 KZ1000
1975 CB750
197? CB750 mutt
1977 KZ1000
20 Nov 2010 07:37 - 20 Nov 2010 07:39
55fbomb wrote:
Perhaps the pads were overheated (possibly from brakes dragging for whatever reason) and are now crystallized....my stock disc setup sucks, not sure if mine just needs rebuilt or they are all kinda weak....
Last edit: 20 Nov 2010 07:39 by Patton.
- 55fbomb
20 Nov 2010 10:43
i think im going to keep my disc setup for now, all i really need to do is figure out how im going to get the clevis at the bottom of the master cylinder push rod to stop hitting the swingarm and cut some new wheel spacers. The rear brake lever would barely turn on the shaft even after i unhooked everything so that may have been some of my problem also, once i cleaned it up it moved fine. i love buying stuff that has sat around for 10 years lol. thanks guys.
1974 CB750
1975 CB750
197? CB750 mutt
1977 KZ1000
1975 CB750
197? CB750 mutt
1977 KZ1000
- roy-b-boy-b
21 Nov 2010 07:19
Take a picture of the problem area. Some one might have used the wrong part. Roy
