Newer-Style Control Levers - '81 GPZ 1100
- GPZ1100_Rider
13 Nov 2010 09:48
Hi:
After spending some time riding my new bike, I've found that I'd like to switch out the control levers to the newer type with the offset in the lever that allows a closer reach. There are several available on Ebay, but they're for newer Kawasakis. Has anyone switched out their older KZ or GPZ levers for these types, with something from a newer model? If it takes a little creative machining with a Dremel, I can do that too.
Thanks in advance.
Marty
Thanks in advance.
Marty
- trianglelaguna
Re: Newer-Style Control Levers - '81 GPZ 1100
13 Nov 2010 12:09
the picture you show is a true gpz lever ?correct?
not the ones you wish to switch too?
this answer may get you a more correct answer
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- GPZ1100_Rider
16 Nov 2010 14:48
Trianglelaguna:
Not sure if it's a true GPZ lever or not. Though I think that the ELR's might have those types.
Mine look (but they're black in color) like the below. As I mentioned, I'm looking for the type that yield a closer reach like the one with the offset in the first pic.
Marty
Marty
- trianglelaguna
16 Nov 2010 16:09
there are two options that are easy enough for low brows like me to recomend...
first if the lever you show really does fit nicely in your perch and the brake is the same shaped type...then you may have either an 81? gpz 1100 or some one put old school shaped levers in your bars....either way...we solve the perch and brake style and we go from there,,
i believe you just need to call Z-1 enterprises and order the correct "gpz" levers,as you may have the eraly style on your bike now...one way to tell is if you have the early style they will be a tad floppy...the area where the bolt goes through the perch and lever is thinner on the early levers i believe.....
or you can get a set of power levers easy enough online by searching GPZ or kz1000 Magura power levers....they also have nice copies of the "magura" for cheaper knocking aroundd the internet
the picture below is of a true GPZ lever
1976 KZ900
2003 ZX12R
2007 FZ1000
2003 ZX12R
2007 FZ1000
- trianglelaguna
16 Nov 2010 16:11
this is a pic of the early kz upgrade levers sometimes called power levers.......they should work also but take a spacer to not be floppy and even then may still be a little loose...imo
1976 KZ900
2003 ZX12R
2007 FZ1000
2003 ZX12R
2007 FZ1000
- trianglelaguna
16 Nov 2010 16:14
can you post a pic of your bars from where your helmet looks down 24" top view with levers and grips and cables shown...
and one of a close up of each assembly...clutch side...brake side.....kneeling in front of the bike camera about a foot in front of the levrs assemblies....then others will know for sure....
good luck
both the gpz and power levers are gonna make a big difference.....
good luck
1976 KZ900
2003 ZX12R
2007 FZ1000
2003 ZX12R
2007 FZ1000
- GPZ1100_Rider
16 Nov 2010 17:35
Trianglelaguna :
Here's the shots of the controls - '81 GPZ 1100. I'll check out Z-1's offerings.
Marty
Marty
- John T
16 Nov 2010 18:56
GPZ1100_Rider wrote:
I have Pazzo levers on my 750 zephyr...
love them.
love them.
True Wisdom Only Comes From Pain.
- trianglelaguna
16 Nov 2010 22:27
wow i wonder if they would go on older kz's...the pazzo type???
yeah you just need a set of power levers for those bars...love that gpz1100...you lucky cholly.......
i'll post and auction for the levers you need in the c-list or a link in the morning
1976 KZ900
2003 ZX12R
2007 FZ1000
2003 ZX12R
2007 FZ1000
