Brakes kz1000m"CSR"
- hamuel89
Brakes kz1000m"CSR"
12 Nov 2010 19:33
Im currently looking for a working used rear brake calipur(current one has some messed up fingers) any suggestions? anyone know any other bike that are combaitable other then the 81-82 Csr/LTD? or if a front brake will work?
Re: Brakes kz1000m
12 Nov 2010 19:56 - 12 Nov 2010 20:00
Hello, Hanuel, and WELCOME to KZr forum!
According to kawasaki.com, the calipers are shared only on the noted models.
Would monitor ebay for a correct replacement.
Meanwhile, a malfunctioning caliper may sometimes be restored to serviceable condition.
Am uncertain about what is being described as "fingers" and what's wrong with them.
Might a picture be available?
Here's a diagram for reference.
Last edit: 12 Nov 2010 20:00 by Patton.
- hamuel89
Re: Brakes kz1000m"CSR"
12 Nov 2010 20:50
What im talking about is the black side of the calipur that holds the rear pad. Someone decide it was a smart idea to Cut into them providing a 1/4-1/3 deep lip close to the bottom of calipur. When pressure is applied the pad isn't vertial it's slanted making only partial contract with the rotor.(i'll see if can get a picture It truly be wildering)
I wish it was as simple as a bad piston or seal.
- H1Vindicator
Last edit: 22 Jan 2013 01:26 by H1Vindicator.
