Frame cutting
  • 78kztwin
  • 78kztwin's Avatar Topic Author
Frame cutting
10 Nov 2010 14:19
#412045
I'm turning my 78 750twin into a bobber. I've seen "Kogging", where they cut the two side backbone supports out. How dangerous is this and is it advisable.
78 kz 750 twin work in progress
  • M357.5
  • M357.5's Avatar
  • Kwakas N' lots of em'
Re: Frame cutting
10 Nov 2010 14:24
#412046
Konging the frame is when you drop the seat rails, then cut the remainder of the rear frame section off behind the shocks...is this what your intending ?
Sounds more like your cutting the 2 frame tubes that run under the tank to the steering head. I've seen guy's do this to run sporty tanks...GUSSET the hell out of it if this is your plan, these old frames flex without cutting tubes out.
83 KZ750L X2 + goodies = Project
84 KZ750L the mini ELR replica replica lol
84 ZX750E Turbo modded n' FAAAAASSSSSSTTTTT
85 GPz900r GREEN N' MEAN
  • 78kztwin
Re: Frame cutting
10 Nov 2010 14:55
#412051
that's what I'm planning, I may take an axtra piece and run it undder the backbone or along side, the tank I'm using has a wide enough tunnel.
