Looking for wide Superbike bars
- seanof30306
10 Nov 2010 06:35
'79 KZ650 B3
So, I have a set of Superbike bars on my bike. I love them.
The only problem I have is the mirrors are useless. I got a pair of mirror extenders, and they work, but they look terrible.
Now, I know all about bar ends, etc, but that's not the way I want to go.
It's occurred to me that if I could find a set of handlebars with the same bend as the superbike bars, but 32-33" wide, it would solve my problem.
My superbike bars' measurements are:
width: 29"
rise: 2.5"
pullback: 4.75"
center width: 4.75"
Those bars, 3-5" wider, would be perfect.
Does anyone know where I might find them?
width: 29"
rise: 2.5"
pullback: 4.75"
center width: 4.75"
"That @#$%!!! KZ650"
79 KZ650 B3
Dual front disc brakes
Z1R 18" front wheel
Pumper carbs w/pods
MAC 4-1 w/ drilled-out baffle
Dyna S ignition w/ Dyna Green coils
WG coil mod
'81 CSR charging system
17/41 gearing
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
- JMKZHI
Re: Looking for wide Superbike bars
10 Nov 2010 06:44 - 10 Nov 2010 06:45
Someone else might know, but the closest alternatives to Superbike bars that I've looked into are the European style & Daytona style.
Also, you could check into getting longer stemmed mirrors. I don't know how long yours are, but the mirrors on the 80s KZ Standard models are longer than those found on the Ltd & CSR models. Since your bike is a Standard model, they might be long already.
Last edit: 10 Nov 2010 06:45 by JMKZHI.
10 Nov 2010 07:04 - 10 Nov 2010 07:12
Might be wrong, but thinking that with other dimensions and running conditions equal, wider handlebar could worsen mirror vibration.
Likely already considered packing internally with some form of dampener such as bar snake, sand, lead, silicone, etc.
Sometimes other areas contributing to mirror vibration are things such as tire balance and roundness, motor mounts, steering head bearings, alignment, general engine tune for smoothest running, etc.
And even supposedly identical mirrors may vibrate more or less differently under the same running conditions at various road speeds.
Last edit: 10 Nov 2010 07:12 by Patton.
10 Nov 2010 07:24
Where line of sight is the main issue, and mirror vibration isn't an issue, length and bend of the mirror stem in relation to handlebar shape and width are factors, along with whether mirror lens is convex to reveal a larger area in the rear view.
Of course, convex shape doesn't much help when looking at shoulder or elbow. :lol:
10 Nov 2010 07:40
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationAm uncertain of mirror shape (round vs rectangular) or stem mount position (bottom or center back) or stem length and bend of the mirrors at hand, or whether they might be oem mirrors on the noted model, but here are a couple of ebay pics for comparison.
- testarossa
10 Nov 2010 07:58
Try looking at some dirtbike handlebars. I have a set that I purchased at a wrecking yard. They have a very similar bend and rise to the superbike bars, and IIRC they are about 32" wide. I would have to measure them to be sure, and that would need to wait until I got home this evening. I simply cut off the small diameter cross bar so that they didn't look like dirtbike bars. I'm thinking that some of the newer dirtbike bars even have a removable crossbar.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
- gane
10 Nov 2010 18:25
Sean, for grins, shift your' search to "Flat track bars" they're usually @ 32" wide. & come in 3 or 4 different bends. (I have a set of the #2 bends on one of my bikes, & am pleased not only with the feel, but the look..Luck G
[img][/img] 1977 KZ1000A1
- bls5050
10 Nov 2010 19:09
When I got my bike, it had the original "longhorn" bars on it, and they really weren't doing it for me. A bike mechanic near me turned me on to Pro Taper SE (Seven-Eighths) bars. He has them installed on all of his track bikes (all newer 1000cc crotch rockets, one is a '03 ninja). They're formed from 5mm wall thickness aluminum, so they're all about some vibration damping. If you go to the Pro Taper website, the SE's are available in a wide variety of widths, heights, and pullbacks, one or more of which should fit your application. Yes they are dirtbike bars, but they have a removable center brace. I left mine on 'cause it makes people say stuff like "hey,those don't go on a streetbike." One last note on the Pro Tapers... The SE's are listed in metric. If you're not familiar with this, multiply inches X 25.4 to arrive at reality in millimeters.
1980 KZ1000st
- MentalMike
- God Bless America!
10 Nov 2010 20:16 - 10 Nov 2010 20:18
I've got the Pro Taper Ricky Carmichael Bar on my ELR and I love em.
As I ride off road as well, I find them very comfy for the street with zero vibration.
I swear to God, it's like I live in a trailer of common sense, and stare out the window at a tornado of stupidity.
1976 Kawasaki KZ900
1978 Kawasaki KZ1000A
1978 Kawasaki KZ650 C
1984 Kawasaki ZN1100 LTD
1985 Kawasaki ZX900A2 GPZ (2)
1985 Kawasaki ZL900 Eliminator
2013 Kawasaki C14 Concours
1976 Kawasaki KZ900
Last edit: 10 Nov 2010 20:18 by MentalMike.
- MentalMike
10 Nov 2010 20:19
1976 Kawasaki KZ900
1976 Kawasaki KZ900
- MentalMike
10 Nov 2010 20:20
1976 Kawasaki KZ900
1976 Kawasaki KZ900
10 Nov 2010 20:26
MentalMike wrote:
Such an Elegant, Gorgeous bike!
Handlebar color compliments both lettering and shocks.
