Dual disc spoke wheel
- hal0tw0
09 Nov 2010 10:02 - 09 Nov 2010 10:02
Id like to know if its possible to add a second disc to the stock 19" front spoke wheel. pardon me if that seems like a stupic question, but I searched and didnt see that info. I like weight difference of spoked wheels over mags, but Id like better braking moreso. Im also considering keeping the stock 19" wheel with the GSXR fork swap im considering over the winter, if thats possible. Just have to machine an axle maybe?
Thanks
Thanks
1976 KA900. VM28 pumper carbs, K&N pod fiters, RC performace 4/1 exhaust, Dyna ignition, Accel coils and wires, Ohlins rear shocks.....more to come
Last edit: 09 Nov 2010 10:02 by hal0tw0.
- kawsakiman
Re: Dual disc spoke wheel
09 Nov 2010 10:45
take the cover off the other side and there are bolt holes for a second rotor.
don't know about the gsxr question though
- Mcdroid
- Gone Kwackers
09 Nov 2010 11:34
In addition to adding a disk and all the additional plumbing, you'll have to upgrade the brake reservoir from a 1/2" system to a 5/8" system.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- JMKZHI
09 Nov 2010 12:12
Just adding some info for a possible alternative...
The 1981-82 KZ1000-CSRs have 48 spoke wheels w a dual disk front brake & a single disk rear. I have no idea how easy it would be to slap those parts onto your 76 900.
- trianglelaguna
09 Nov 2010 12:43
the 76-78 ltd 900-1000 front brake sets go cheap often and come as a whole set....lever ,front master cyl and lines and calipers...then you only need a disk that matches yours....and the two caliper bolts and maybe the four disk bolts...it also depends how many bolts the disk/hub you have now have as to the matchers bolt pattern you buy...
folks run the calipers behind the forks when mounting two disks which mean switching and reversing the right and left fork legs to rotate the dual mounts to the correct side
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- M357.5
- Kwakas N' lots of em'
09 Nov 2010 12:52 - 09 Nov 2010 12:55
Now this is on my 750B1, but this is what you will need to do the swap ( Tri stated above everything you need )
My swap was KZ1000 disks, left caliper, lines, spliter, 5/8 bore master. Swapped fork tubes from Left to Right side to get the rearward facing caliper orientation.
83 KZ750L X2 + goodies = Project
84 KZ750L the mini ELR replica replica lol
84 ZX750E Turbo modded n' FAAAAASSSSSSTTTTT
85 GPz900r GREEN N' MEAN
Last edit: 09 Nov 2010 12:55 by M357.5.
- trianglelaguna
09 Nov 2010 13:20
killer twin there...very cool...bet you get a lot of folks commenting when you take that one out..nicer than most i see twin 750 kaws imo...!!!!
1976 KZ900
2003 ZX12R
2007 FZ1000
2003 ZX12R
2007 FZ1000
- M357.5
09 Nov 2010 13:24
She is a sweet heart for sure, sold it early this spring to a friend. It's cool though, he lets me take her out on dates if I want LOL.
- hal0tw0
09 Nov 2010 14:22
Thanks for all the replies, and yes that bike is pretty sweet.
