Extended swingarm
- Mstine2
Extended swingarm
04 Nov 2010 15:56
Hello. I am new to the KZ world and am looking to make some mods. First of all my bike is a 1980 KZ1000 that I bought laying in the mud in my friends backyard. I have since tore it down to the bare frame and have a plan but was hoping for some help with dimensions on a extended swingarm. I have a mill, engine lathe, mig and tig welder so I am going to make my own(or attempt to). I am wanting to make one 4 inches longer than stock the question I have is what would the width need to be at the rear of the arm if I wanted to run a 18x5.5 rear rim with a 200mm rear tire? Any help anyone on here could offer would be great as im sure there has been somebody on here try or done this. Thanks.
- z1kzonly
Re: Extended swingarm
04 Nov 2010 17:12
Longer swingarms are a commodity on ebay!
There was a D&G extended swimgarm that sold cheap! Because it had 3 axle adjusting holes on it. Only went for $58.
The same time one sells for $250. Both chromeoly tubing.
Extend a stock one, buy a Suzuki GS.
I made a stock one 3 in longer. Used stock material to extend a stock one.
- rslingshot
04 Nov 2010 17:49
The best thing to do is find out what rear wheel you are going to use gsx-r, zx-12,busa etc etc etc. Because there is a diference in the hub width, for the most part your suzuki wheels are pretty much the same give or take a little. I will send you the measurements for the hayabusa gsx-r zx-14 zx-12 and honda 600rr if you want.
- Mstine2
04 Nov 2010 18:45
That would be great if you dont mind to send that to me. My e-mail is Mstine2@aol.com. Thank you.
- drag cow
Last edit: 20 Nov 2010 09:32 by drag cow.
- drag cow
- StreetfighterKz
05 Nov 2010 04:37
If you want to use a 200mm tire plan on using a 6" rim to get a proper tire profile. But like rslingshot said, find a rim and build your swingarm to suit.
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- rslingshot
05 Nov 2010 12:59
hayabusa
gsx-r 600 750 1000' from 2000 to 2007 10.312 at back
zx-14
zx-12 10.750 at back
haonda 600rr 9.8125 at back
zx-14
- big mike
03 Dec 2010 12:47 - 15 Dec 2010 16:35
be carfull guys you can go as wide as a 6.25 wide wheel with a 200 tire in a 17 in thats max with a 5/8 ofset front sprocket and a 530 cain we build this combo alot so if any one needs any help let me know 253 582 2486
Last edit: 15 Dec 2010 16:35 by big mike.
- big mike
15 Dec 2010 16:37 - 15 Dec 2010 16:38
you start using wheels of the new style bikes the chain line is way out and the tire will end up being offset to the right side to get the chain to line up so be carful check it befor you buy a wheel you cant use i hope this helps
:woohoo:
:woohoo:
Last edit: 15 Dec 2010 16:38 by big mike.
- big mike
15 Dec 2010 17:53 - 15 Dec 2010 17:54
i just got the tape out lol and here is the lowdown rslingshot might check this too just to keep me honest ok from the center of the tire to the center of the sprocket is just a 32nd under 4 1/2 in in mi opinon this is max with the 5/8 offset front sprocket and a 530 chain ( i used to use a 630 chain on my drag bike with no prob) so i would think any wheel that falls under these nombers would be ok to use ( i think lol)
Last edit: 15 Dec 2010 17:54 by big mike.
- kz1k
- You Cant Fix Stupid!
15 Dec 2010 18:40
big mike wrote:
im counting on ya mike. :silly:i just got the tape out lol and here is the lowdown rslingshot might check this too just to keep me honest ok from the center of the tire to the center of the sprocket is just a 32nd under 4 1/2 in in mi opinon this is max with the 5/8 offset front sprocket and a 530 chain ( i used to use a 630 chain on my drag bike with no prob) so i would think any wheel that falls under these nombers would be ok to use ( i think lol)
1978 KZ1000A2
