1983 KZ1100 L1 LTD Shaft Fork Oil Amount???
- pctech101
04 Nov 2010 12:21 - 04 Nov 2010 12:22
I am trying to replace the oil in my forks and the book doesnt list the amount of oil to put in. You are suppose to messure amount of oil in the forks until it reaches a certain amount of measurement. I need to know the amount and wether the forks should be extended or compressed.
thanks
thanks
Last edit: 04 Nov 2010 12:22 by pctech101.
- Motor Head
Re: 1983 KZ1100 L1 LTD Shaft Fork Oil Amount???
04 Nov 2010 14:09
The manual I have, FSM pdf, shows this chart,
Hope this helps. It doesn't show anything else even in the 83 supplement at the back.
- pctech101
05 Nov 2010 08:42 - 05 Nov 2010 08:53
I have similar information.
But nothing is listed for the 83 LTD Shaft (L1)
Some ol' timer probably knows this and I am hoping to stumble upon him...
I dont know enough about bikes to make an informed decision.
I actually drained the left side. measured the right side fully extended with spring removed. Put that same amount in left. then drained right and put same measurement in.
I still want to know measurement that way i know if it is low or not.
thanks
thanks
Last edit: 05 Nov 2010 08:53 by pctech101.
05 Nov 2010 09:53
For more consistency, fork fluid level is imo best measured with front end suspended.
Once the correct volume is achieved, would suggest fashioning a dip-stick (from a slim wood dowel or whatever) marked to show distance between fluid level and top of fork tube with springs remaining inside. This helps eliminate future need to measure exact volume and messiness of removing springs.
05 Nov 2010 10:20
Might check kawasaki.com site to compare part numbers of front fork components among various 1983 KZ1100 models.
Am thinking with the same components in the working portions of the forks that the fluid levels would also be the same.
Bear in mind that a different color between otherwise identical parts will result in different part numbers (such as for example, color of lower fork tubes.)
If needed, for help using kawasaki.com,
click here > kzrider.com/index.php?option=com_kunena&...w&catid=13&id=376734
