muffler covers
  • coach59
  • coach59's Avatar Topic Author
muffler covers
29 Oct 2010 20:41
#409850
Anyone know what size (and type) of screws I need to install muffler covers on a '82 KZ750LTD? The service manual also indicates a washer on both sides, but doesn't specify what size. Ideas ?
Thanks -
TH
Re: muffler covers
29 Oct 2010 21:01
#409852
coach59 wrote:
Anyone know what size (and type) of screws I need to install muffler covers on a '82 KZ750LTD? The service manual also indicates a washer on both sides, but doesn't specify what size. Ideas ? Thanks - TH
Per kawasaki.com, 2 each of the following:
SCREW PAN HEAD 6X20
WASHER SPRING 6MM
SCREW PAN HEAD 6X8
WASHER PLAIN 6MM
Click > How to find stuff on kawasaki.com
Good Fortune! :)
  • coach59
Re: muffler covers
29 Oct 2010 21:39
#409863
Wow...excellent. Thanks for the resource.
TH
  • coach59
Re: muffler covers
31 Oct 2010 08:50
#410063
Is there a right and a left cover ? Or, are the same? I installed one side - and it looks OK, but can't tell. If everything lines-up OK and it appears to fit, do I have the right side installed ?
Re: muffler covers
31 Oct 2010 11:02
#410081
If the part numbers are identical, the left and right covers would be the same.
If the part numbers are different, the left and right covers would be different.
Good Fortune! :)
