Removing paint for ground
- mvent
22 Oct 2010 17:23
Going to start assembly soon and need to know where to remove paint on frame for grounding points, can anyone tell me? Bike is 78 KZ1000 A2A
Thanks
Thanks
76 KZ900
76 XLCH
78 KZ1000
04 FLSTFI 120 ci
- PLUMMEN
Re: Removing paint for ground
22 Oct 2010 18:37
i usually ground to back corner of cases,you could run a jumper with a ring on it to a bolt on battery box if youre worried about it
22 Oct 2010 22:11
mvent wrote:
On each set of points, one contact is permanently grounded by being screwed into the large round backing plate.
[Click on image to enlarge view.]
Thanks
22 Oct 2010 22:24
If relevant, the negative battery cable attaches to ground by connecting to rear of engine.
The large round backing plate attaches and grounds to the engine which connects to the negative battery terminal via the cable attached to rear of engine.
Some builders attach the negative battery cable to the frame instead of to the rear of engine. Imo, this risks a less stable ground for the ignition, because it then further relies on conductivity between engine and frame.
Where the negative battery cable is connected to the frame (instead of to the engine), paint should be first removed from the frame where the cable lug attaches.
- mvent
23 Oct 2010 05:22
Thanks for the replies, trying to cover all bases before actual assembly, never would believe EVERYTHING needs to be messaged before its put back together
76 KZ900
76 XLCH
78 KZ1000
04 FLSTFI 120 ci
- Capt America
- Born Bad
23 Oct 2010 15:43
I must be a worry-wart or just a bit excessive perhaps.
I've always had two ground sources, one to frame, one to motor, and a smaller lead off each for the wiring harness ground so it has double connections as well.
Capt A
merica
1983 K1 750 twin
Ontario, Canada.
1983 K1 750 twin
Ontario, Canada.
