Are these Mulholland shocks?
  • Kapahulu
  • Kapahulu's Avatar Topic Author
22 Oct 2010 14:06
#408303
I'm enjoying riding my '79 LTD now that the carb tuning is in the ballpark.
The back end rides like a hardtail. I think these are the stock Mulholland shocks, want to check and see what others think.
If they are the stock shocks, is there anything worthwhile doing with them? For example, putting softer springs on them? I weigh about 175 lbs.
And if they should be trashed, what AFFORDABLE shocks are recommended? I'm thinking about Progressives but they look so plain. Works looks nice but $$$. How about YSS or Hagon?
Thanks, Mike
2strokeworld.com
  • oldkaws4ever
  • oldkaws4ever's Avatar
  • Have no regrets...... You only live once.
Re: Are these Mulholland shocks?
22 Oct 2010 14:21
#408308
Not sure what brand those are. Is there a chance that the shocks are adjusted to there stiffest setting? If they are indeed trashed i have heard nothing but great things about Hagon shocks.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
  • Galactica
  • Galactica's Avatar
22 Oct 2010 15:39
#408319
I don't think they're Mulhollands, Konis perhaps. I kike my Hagons.
GL
R
77KZ1000
76 KZ900
  • mjg15
  • mjg15's Avatar
22 Oct 2010 15:52
#408320
Konis usually have a ramped preload collar, these look like S&W's (hood over top of spring) or maybe Monroe. Both are quality aftermarket shocks. Maybe a rebuild is in order, or possibly the spring rate is wrong for your weight.
'80 Z750fx
'81 KZ550A
'81 GPz550's, Too many!
'82 KZ1000R
'82 GPz750
'90 ZR550
Project photo album: s163.photobucket.com/albums/t289/mg15_ph...GPz-ZR550%20project/
s163.photobucket.com/albums/t289/mg15_ph...current=DSC01286.jpg
  • Kapahulu
22 Oct 2010 16:44
#408327
Yeah I also thought they look like S&W's. First time I saw the bike I thought I'd scored on the shocks. As mentioned in the first post, the back end rides like a hardtail. The springs are set with the minimum preload. Something is wrong.
I think I'll check with Z1 Enterprises and see about getting some lighter springs.
2strokeworld.com
  • Nebr_Rex
  • Nebr_Rex's Avatar
22 Oct 2010 17:41
#408336
Thanks, Mike
maybe mdi
is there anything stamped on the shock body below the spring
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • C.T.
  • C.T.'s Avatar
22 Oct 2010 18:24
#408349
Not sure what brand they are, but they are not stock. This picture shows my stock 1979 ltd 1000 Mulholland set up. I would guess they are S&W but not sure.
1979 KZ1000 L.T.D. B-3 Original Owner
2003 ZRX 1200R
1976 KZ900 A4 Project bike
Ione Ca.
  • TerryK
  • TerryK's Avatar
22 Oct 2010 20:26
#408378
Both sets look like S&Ws to me. The ones in the first picture are later models.
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
  • z1kzonly
  • z1kzonly's Avatar
22 Oct 2010 22:03
#408394
These are the stock Mulholland shocks.
These came stock on the LTD models.
Notice the little yellow sticker along the bottom of the shock. It said Molholland
  • z1kzonly
  • z1kzonly's Avatar
22 Oct 2010 22:04 - 22 Oct 2010 22:05
#408396
This picture for Mulholland shocks
Last edit: 22 Oct 2010 22:05 by z1kzonly.
  • z1kzonly
  • z1kzonly's Avatar
22 Oct 2010 22:08
#408397
By the way, whosever this LTD is?
It is a nice, clean, stock motorcycle.
  • Kapahulu
23 Oct 2010 00:38 - 23 Oct 2010 00:53
#408406
Okay I figured it out! I was reading a motorcycle magazine today and it had an ad for Progressive Suspension shocks. The top of the shock in the ad looked just like my shocks.
I went home, took a closer look at the shocks and on the springs there's a small logo that says Progressive Suspension
1394 75/120
So I wonder why the handling is not all that great? No wobbles or anything, just doesn't seem like the rear end is very compliant with bumps. The spring rate, I think that would be okay? Maybe it's that big 16" rear tire. The profile is fairly flat too.
Well it's been a long time since I rode a KZ. Last one I had was an '83 ELR which I sold in 1988.
Just picked this '79 LTD up in June and started riding it in the last couple of weeks as the carburetion was sorted out.
So if you have any tips on handling improvements let me know! I do have an 18" spoke rear wheel I'm planning to put on the KZ in the near future.
2strokeworld.com
Last edit: 23 Oct 2010 00:53 by Kapahulu.
