1978 Z1R Steering Lock????
  • flhwesty
  • flhwesty's Avatar Topic Author
21 Oct 2010 18:37
#408111
I have a very earlt serial numbered 1978 Z1R, under #200. I have posted a picture of the steering lock. Is this the normal location? A friend mentioned it was in an odd place. Did they use a different triple tree on earlier models?
1983 GPZ750
1977 KZ1000LTD
1978 Z1R
1981 GPz1100 KZ1100-B1
  • flhwesty
Re: 1978 Z1R Steering Lock????
21 Oct 2010 18:39
#408113
Ok here is picture.
1983 GPZ750
1977 KZ1000LTD
1978 Z1R
  • flhwesty
21 Oct 2010 18:43
#408114
Another picture, with lock number.
1983 GPZ750
1977 KZ1000LTD
1978 Z1R
  • PLUMMEN
  • PLUMMEN's Avatar
22 Oct 2010 07:21
#408218
thats normal location for z1/kz through 1978 anyway,not sure about z1r.
are those extra bolt holes for fairing mounts?
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
22 Oct 2010 07:48
#408224
that thing has had some mods done to it.i know my 1980 z1r has the lock in the side of the neck.i will have to try and remember to check my 78 this weekend.those welded on tabs on the bottom are not factory.it looks like someone has modded another tree to work on a z1r.
  • JakeB
  • JakeB's Avatar
22 Oct 2010 07:55 - 22 Oct 2010 07:59
#408225
The steering lock on my mine is on the side of the steering stem. It may be that the really early Z1-Rs used the standard frame and needed to use the old triple trees as well to keep the lock. Can you confirm that it is indeed a Z1-R frame number?
My serial number is around 1400 and this is what the steering lock looks like;
1978 Z1-R
Last edit: 22 Oct 2010 07:59 by JakeB.
  • JakeB
  • JakeB's Avatar
22 Oct 2010 08:02
#408227
Sorry couldn't get the pic to post.
1978 Z1-R
  • PLUMMEN
  • PLUMMEN's Avatar
22 Oct 2010 19:01
#408360
i saw a blue 78z1r tonight,damn minivan couldnt keep up with him though! :woohoo:
  • TerryK
  • TerryK's Avatar
22 Oct 2010 20:29
#408380
Thats where the lock is on my 77 1000. Maybe the early Z1Rs had the same setup.
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
