Sticking rear brake
  • KZ1100 Bully
  • KZ1100 Bully's Avatar Topic Author
Sticking rear brake
21 Oct 2010 15:50
#408026
Hi, My rear brake sticks. I think it is just the lever spring as it does not return all the way up. I can put my foot under it and lift it up and the brake will release.
Or do I have a bigger problem?
1983 Kawasaki KZ1100 Spectre D2
  • hocbj23
  • hocbj23's Avatar
Re: Sticking rear brake
21 Oct 2010 17:06
#408060
check and be sure spring is properly mounted and/or is not broken.bj
  • roy-b-boy-b
  • roy-b-boy-b's Avatar
21 Oct 2010 19:10
#408129
How much travel does the brake pedal have?
If your spring is good it might be the brake pads are reaching thier wear limit. Roy
  • TexasKZ
  • TexasKZ's Avatar
21 Oct 2010 19:16
#408131
crud and corrosion on the brake pedal pivot?
  • steell
  • steell's Avatar
21 Oct 2010 19:35
#408137
That's the usual cause. Solution is to remove the brake pedal, clean and lubricate the pivot then reinstall.
  • KZ1100 Bully
22 Oct 2010 10:14
#408254
The pedal goes down about a third of the way. The brake pads new last year with 3000 miles on them now. Sounds like the pivot needs lube and cleaning will install a new spring as well.
Thanks guys for the help.
  • donthekawguy
  • donthekawguy's Avatar
22 Oct 2010 15:16
#408314
When i put the new swingarm on my bike the pedal would barely move. I got it off cleaned up the post and pedal, lubed it up and all is good. If the problem doesn't go away try cleaning out the groove in the caliper where the seal sits. Those seem to get filled up with crud and won't let the piston return back into the caliper.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
  • KZ1100 Bully
18 Nov 2010 09:12
#413289
I took the brake pedal leaver off and removed the pivot. It was dry and full of crud and corrosion. Cleaned and lubed the pivot reinstalled everything. Wow works great now.
Thanks guys
