fork slider stuck
  • joebiker83
  • joebiker83's Avatar Topic Author
fork slider stuck
19 Oct 2010 14:56
#407609
in doin the fork seal replacement on a 76 kz900, after both, bottom allen removed and top cap removed the slider went down into the fork body and is siezed.... what happened? everything else came out(except the aluminum collar that goes around the bottom bolt) has anyone else had a fork assembly sieze on itself when disassembled?
