z1r front master cylinder
  • asevans
  • asevans's Avatar Topic Author
10 Oct 2010 18:15
#405779
Im having a problem with my front master cylinder on the z1r rebuild. it is stuck. it says in the manual that you can kill yourself trying to mess with it, and that you should take to the kaw dealer. it also says that if it is froze you just have to replace it.
Is there any way to fix it or do i have to just have to hunt a good used one down?
thanx
Aaron
1976 kz900 Mostly stock
1978 Z1-R Project
  • PLUMMEN
  • PLUMMEN's Avatar
Re: z1r front master cylinder
10 Oct 2010 18:29
#405788
i didnt see a listing on z1 enterprises,you might try calling them.
babbits lists the comeplete assembly for $264.00 :S :blink: :unsure: :ohmy: :huh: :dry: :blush: they also list seperate parts depending on what you need .
  • asevans
10 Oct 2010 19:02
#405815
i think im going to try to heat it up and see if i can free it up.
anybody ever done this before.
i have no idea what i need. ill try to take it apart and see whats up.
1978 Z1-R Project
  • xmoney
  • xmoney's Avatar
10 Oct 2010 20:02
#405860
I have the same problem on my build up . I have been letting mine sit in penetrating oil for a week and it will only move inward. I can put shop air to it and it will move just a little and then no farther . I have found some times it is better to go with a new part . After all it is your brakes!! Better to be safe than sorry!!
1992 Harley Davidson FXDC Full Custom
1982 KZ 750 N1 Cafe project
1970 BSA Thunderbolt OIF W/ Lightning twin carb Head Bobber/ Cafe Stayle (Project )
  • MFolks
  • MFolks's Avatar
10 Oct 2010 20:12
#405864
Before resorting to force, make sure there is no snap ring/circlip holding the piston in. www.z1enterprises.com sells a long nosed snap ring plier for just this type of job.
  • asevans
12 Oct 2010 12:30
#406150
Ok i got the front freed up. still letting it soak in blaster. The rear is froze too. ahgggg.
1978 Z1-R Project
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
12 Oct 2010 13:02
#406154
man those z1r front master cylinders always worry me,because they are one of those z1r specific parts that is not used on other models.i am glad you got yours freed up.i hope the rear cooperates with you.
