chain hitting frame
  • hypnohio
  • hypnohio's Avatar Topic Author
chain hitting frame
10 Oct 2010 17:37
#405772
I'm working on an '82 kz440 that was converted from belt to chain drive many moons ago. I checked the Kawasaki website and it should be a straightforward swap, but the chain is hitting the brace where the beltguard attaches to the frame in front. I put it up on the centerstand, put it in gear, and periodically the chin starts to jump around and hits the brace sideways as well as up and down. It's adjusted properly, but is literally wearing its way into the brace. I hope this description makes sense. It's got me stumped. engine sprocket problem, possibly? I'm open to any ideas. thanks
sk
1982 KZ440 LTD
2003 EN500 C
2006 Virago 250
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
Re: chain hitting frame
10 Oct 2010 18:39
#405798
You say the chain jumps around and is wearing into the brace. Is this something new, as you say the change from belt to chain was done in the distance past. If it just started I would first look at the sprockets and chains. How old are they, is it time for a new set. If so get both sprockets and a chain at the same time.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
  • hocbj23
  • hocbj23's Avatar
10 Oct 2010 18:41
#405800
x2.
  • TerryK
  • TerryK's Avatar
10 Oct 2010 18:45
#405806
Belt guard? Is it still needed?
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
  • hypnohio
11 Oct 2010 02:33
#405894
the bike is new to me, but from the looks of the bracket it's been going on for a while. wearing a groove into steel takes time, I would think. checking the sprockets is my next move. RE: the guard, it's the bracket that's the problem, and that's part of the swing arm.
1982 KZ440 LTD
2003 EN500 C
2006 Virago 250
  • Old Man Rock
  • Old Man Rock's Avatar
11 Oct 2010 05:37
#405912
Vertical movement on the chain I can see but side to side jumping.... :S
Something not write there in your alignments, CC sprocket to wheel hub offsets (chain path) etc....
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
11 Oct 2010 05:50
#405918
Can you get some pictures of the area in question? Ed
  • hypnohio
11 Oct 2010 08:57
#405955
I'll get a picture soon as I get home from work.
1982 KZ440 LTD
2003 EN500 C
2006 Virago 250
  • hypnohio
11 Oct 2010 14:29
#406015
Ok, I'm hoping I can figure out how to attach a picture. After looking at the pictures in the service manual it almost seems like the sprocket(s) are too small, making the chain closer to the bracket than it should be. Anyone know what the diameter of the sprockets should be? Other than that, I haven't a clue but the chain definitely is much closer to the bracket than in the pics.
1982 KZ440 LTD
2003 EN500 C
2006 Virago 250
  • hypnohio
11 Oct 2010 14:58
#406019
just checked the service manual. sprockets for chain drive: 216.5/64.9mm. pulleys for belt: 264/95mm. That seems like that would solve the problem, but I can't figure out why the chain sprocket wouldn't work since the swing arm and related parts are identical on the A1 and D4. I'm not that great at eyeballing a sprocket to tell if it's worn, but I'm guessing that may be it, but the chain still seems too close to that bracket to me. Ideas?
1982 KZ440 LTD
2003 EN500 C
2006 Virago 250
  • PLUMMEN
  • PLUMMEN's Avatar
11 Oct 2010 14:59
#406020
if chain is flopping side to side id guess its worn out,will removing bracket help?
have you checked front sprocket to see if its tight?
  • hypnohio
11 Oct 2010 15:34
#406025
haven't checked the front sprocket yet,but will do so. thanks. the bracket is welded on so it'd be a bit of a chore to remove it, and actually I'd like to figure out what's really going on
1982 KZ440 LTD
2003 EN500 C
2006 Virago 250
