1974 KZ 400 Project Questions
- buffalobrian
07 Oct 2010 17:29
I just torn down my new 1974 KZ 400 Project. I am going to see how far I can go with this bike.
I am basically replacing everything I can. I was wondering:
Are there any other Front Ends that will fit the Frame? I want a solid rider. I am not sure if I trust the Triple Trees and forks. I need front brakes anyway, and was thinking something more modern. Is there something that will bolt right on?
- kz1k
- You Cant Fix Stupid!
Re: 1974 KZ 400 Project Questions
07 Oct 2010 17:31
why wouldnt you trust the forks? you have any pics of the bike, or parts?
1978 KZ1000A2
- PLUMMEN
07 Oct 2010 17:32
nothing wrong with the stock frontend an oil change and maybe some new fork springs cant fix
- buffalobrian
07 Oct 2010 17:37
Well that actually makes me feel better. I just figured since I was addressing so much why not change.
I guess the other thing is that I bought the bike early on in the project. The kid I bought it from has 440 mag wheels and swing arm. As well as the sprocket from the 400. Not sure if the front forks are from the 440 or the 400. I was thinking of a Bremlo front brake set up but not sure if I can mount it.
- PLUMMEN
07 Oct 2010 17:50
got pictures?
the 74 kz400 i had came with wire wheels with single disc on front and drum on rear
- buffalobrian
- buffalobrian
07 Oct 2010 17:52
Try to post some but it says my image is to large?
- PLUMMEN
07 Oct 2010 17:54
open with paint and resize,easiest way i know how to resize.
ok,thats actually the only way i know to resize!:blush: :woohoo:
- buffalobrian
- buffalobrian
07 Oct 2010 18:09
I can't figure it out!! I am quiting for now. But it is a disk front. I have calipers from the 400 and the 440 (came in a box of loose parts) one fits, but I am not sure which. I suppose if you feel confident in the forks, you probably feel the same about the brakes. Maybe just a caliper rebuild, new lines and pads.
- PLUMMEN
07 Oct 2010 18:34
the biggest single problem on bikes in early 70s was finding decent tires that could hold up to a disc brake! :laugh:
its not an h2 750,i wouldnt worry too much
