Club bar swap wiring help
  • Brian kz650
  • Brian kz650's Avatar Topic Author
07 Oct 2010 11:28
#404923
Hey all, I am swaping the stock bars for clubman bars.I want to run the wires through the bars I have searched the forum,if I have this correct it looks like the best way to do this is to disconect the wires at the harness and pull the wires out.Not disconnect from the levers.It seems my conection is under my gas tank,and pretty hard to get at.Do I have to take the tank off? any guidance would be great.Thx,Brian
  • testarossa
  • testarossa's Avatar
Re: Club bar swap wiring help
07 Oct 2010 11:53
#404940
Yes you need to get the tank off to disconnect the switch pods from the main wiring harness. I know it seem intimidating until you do it the first time. All the wires are color coded so they match up easily when you re-connect them. There are two bundles of bullet connectors under the tank.
Be careful pulling the wires through the bars. I managed to pop three of the connections soldered in my switch pods when I pulled mine. As to trying to pull the wires back through the bars all I can say is good luck. I'm guessing that the factory pulled the wires first and then crimped on all the connectors. You'll find out what I mean when you go to pull the wires. I wasn't about to try to get them back through there. Unless the new bars have a larger diameter inside than the stock bars.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • Brian kz650
07 Oct 2010 12:07
#404953
Thanks testarossa, is there anything special I should know about taking off the tank, or the order of unbolting one piece or another first. I also have to drill holes in the new 7/8 bars. I was tempted to just leave the wires outside of the bars,but I think running them inside will be much cleaner.Thx,Brian
  • testarossa
07 Oct 2010 12:58
#404969
Tank shouldn't be too tricky. Remove as much fuel as possible. I suggest riding as an effective fuel removal tactic. Shut off petcock, disconnect the fuel and vacuum lines to petcock if present. I'm not sure how the back end mounts on a KZ650, but on my 1000 there is a strap under the front of the seat. Flip the seat up, undo said strap, and pull the tank straight back until the front end unhooks. At that point you should be able to lift it straight off.
Good luck.
PS I suggest that you de-burr the edges of the holes in your stock bars before you attempt to pull the wires. The holes are stamped in and have jagged edges perfect for cutting wires and snagging connectors. Possibly shoot some form of lubricant in the bar to assist in sliding the wires through.
2004 ZX-10R
Angola, IN
07 Oct 2010 13:20
#404977
Good news - removing the tank on the '77 KZ650 couldn't be easier. Turn petcock to "OFF"; disconnect fuel hose at petcock; open seat; lift rear of tank (it has a tang that goes into a rubber bumbper on the frame); gently pull tank up and toward the rear. That's it. There's nothing except the fuel hose to unhook. Be careful to watch the front of the tank so it doesn't hit the steering stem when lifting it off the frame or you may chip the paint. And be sure not to let the 2 rubber disks on the front of the frame fall off and get lost. You will see them when you remove the tank; the front of it engages them. Ed
  • MFolks
  • MFolks's Avatar
07 Oct 2010 14:18
#404987
If you can borrow or buy a Dremel tool(a small hobby die grinder) it comes with a selection of stone rotary bits perfect for removing the burrs inside new handle bars.
Use the highest speed for better control, and have both hands on the tool if possible. For the best result, put the handlebars in a vice, to prevent scarring the chrome/paint, wrap the bars with several layers of rags and tape.
If the burrs are not removed, they will strip the insulation from your wires in a second! Noting quire like troubleshooting a dead short inside new handlebars.
  • Brian kz650
07 Oct 2010 19:20
#405099
Thanks for all the replies, I will be starting this tomorrow,hopefully finishing tomorrow as well, next will be chopping the back of the frame and putting on a cafe seat,but one thing at a time, thanks again,Brian
07 Oct 2010 21:23
#405144
You're going to hacksaw a '77 KZ650? Egads! Oh well, another one bites the dust. :( Ed
  • Brian kz650
07 Oct 2010 21:44
#405145
Sorry to offend you 650ed with my chop, I will still be able to use the stock seat if I want as I am only cutting a few inches off. That may ease your pain. I have a problem with leaving stuff alone,I always have to mess with it.I love the cafe, and flat tracker look since I was a kid and thats why I got this bike.Thx again guys for the tips on the tank and the dremel. Thx,Brian
08 Oct 2010 07:26
#405167
Me too, but I've never seen a cafe or flat tracker that looks good with 4 cylinders. To me, the engine is simply too wide for that style to look proportioned right. I'm more of an old school guy who considers flat trackers and cafes to be twins or one lungers. Ed
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
10 Oct 2010 20:15
#405865
Not quite Cafe but what do you guys think of this 650?:
I've got the wires outside the bars on my bike. Have had them that way with a few different style of bars. Does tidy them up inside though.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • Brian kz650
11 Oct 2010 20:01
#406062
Just wanted to say thanks for the help,650ed,thanks for advice on taking off the tank,I would probably have been staring at it for a while trying to figure it out. I did the bars this weekend,when I hooked up the electric I was expecting a problem, whenever you start really bending and pulling 33 yr old wiring you never know. But everthing was good,While the stock bars were really comfortable,the clubmans are more my style,and I like them better going into turns.Thanks again all.Brian
