Kinky Chain
- havakaw
Kinky Chain
02 Oct 2010 05:34
I replaced my chain and sprockets about 3 years ago,and only have about 5-6,000 miles on them.Sunstar sprockets and an RK O-ring chain. 630 series.(Overkill,I know) I noticed the other day that a coupple of links are kinda "stuck" a little up/down/up/down while the others are straight.Can I take off the chain and clean it out somehow and then re-oil it? I have been using Spectra's O-ring chain oil on it pretty regularly.It makes a sticky mess when the excess flings off,but it keeps it quiet.Bike is '80 750 LTDh.
'80 KZ 750 LTD-H
'82 KZ 1100 A-2 Shafty (ex-bagger)
- dejavoodo41
Re: Kinky Chain
02 Oct 2010 07:27 - 02 Oct 2010 07:31
I'd try using a chain cleaner to ensure that all of the crud is out of the links and then lube it and see if that helps. I know a lot of off road guys have to do this to get all of the sand and what not out of the chain. They say it increases the chain life so it may be worth a try. In a pinch I've used WD-40 and a tooth brush to break down the grime to get it clean then whipe it down with a rag and then use my normal lube.
1977 KZ1000A With 1980 KZ1000A MKII engine, Wiseco 1105 kit, Dyna S Ignition, 3 Ohm Dyna Coils, Cams, Mikuni RS34 Carbs, Vance and Hines Pro Pipe with Comp Baffle
New Smyrna Beach, FL
Last edit: 02 Oct 2010 07:31 by dejavoodo41.
- TeK9iNe
- What did you do!?!
Re: Kinky Chain
02 Oct 2010 07:28
dejavoodo41 wrote:
+1 Spray hard into the joints with a certified cleaner.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- PLUMMEN
- DoubleDub
Re: Kinky Chain
02 Oct 2010 08:51
PLUMMEN wrote:
That'll get the "kinks" out in a hurry... :blush:
- mjg15
Re: Kinky Chain
02 Oct 2010 10:15
Patton wrote:
Chain ? I don't see any chain !
'80 Z750fx
'81 KZ550A
'81 GPz550's, Too many!
'82 KZ1000R
'82 GPz750
'90 ZR550
Project photo album: s163.photobucket.com/albums/t289/mg15_ph...GPz-ZR550%20project/
s163.photobucket.com/albums/t289/mg15_ph...current=DSC01286.jpg
'81 KZ550A
'82 KZ1000R
'82 GPz750
'90 ZR550
- trianglelaguna
Re: Kinky Chain
02 Oct 2010 10:34
just get a new chain..if after a few tries lubing and cleaning and it still comes back...if the sprockets are decent i can get two chains out of em...if your doing burnouts and stuff(your avatar) there may be a stretch in the chain....hard launches and burnouts and stuff "can" eat chains imo.....
kinky chains are best left in the nightstand
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- havakaw
Re: Kinky Chain
02 Oct 2010 11:35
OK-Thanks,but the pics aren't helping me get any REAL work done!!!And the avatar pic is a copy and paste from a "Redneck Pics" e-mail a friend sent,but I love it any way.Going to the bike shop for some stuff,and I'll see if they have cleaner(or what they reccomend) and a new can of lube.(For the chain. LOL!!)
'80 KZ 750 LTD-H
- PLUMMEN
Re: Kinky Chain
02 Oct 2010 13:59
to clean it id normally soak the hell out of it with simple green and head for the car wash,take it out for a ride to dry it out before oiling it down
- havakaw
Re: Kinky Chain
02 Oct 2010 15:42
Bike shop guys said to take it off and soak it in some kerosene for a bit.I got the chain cleaner brush they were hawking,and a can of Bel-Ray O-ring chain lube.The parts guy said he uses it,and so does the service dept.Guess I got a side project tomorrow.
'80 KZ 750 LTD-H
- PLUMMEN
Re: Kinky Chain
02 Oct 2010 16:11
try the simple green and carwash trick first before tearing it all apart,take chain gaurd off to make it easier to clean up at the carwash
