77-78 KZ1000 axles
  • kenskz1000
  • kenskz1000's Avatar Topic Author
77-78 KZ1000 axles
27 Sep 2010 17:39
#402310
Would the 77-78 KZ1000A front and rear axles be the same as the 77-78 KZ1000B LTD axles?
  • Motor Head
  • Motor Head's Avatar
Re: 77-78 KZ1000 axles
27 Sep 2010 17:48
#402312
www.kawasaki.com/DefaultFrame.aspx?strCo.../VICHOOSEVEHICLE.ASP
If you check here you will get your answer, not that some of the guy's wouldn't know. But these are the "Gospel"
  • PLUMMEN
  • PLUMMEN's Avatar
27 Sep 2010 18:06
#402319
yep,front axle and wheel and forks should same as kz650,sliders are just a little shorter on a 650 B)
