Replacing swing arm, need some candidates
- Kitten Tooth
24 Sep 2010 23:04
Im looking to get a crotch rocket swingarm of some sort for my bike to do a streetfighter type thing. I heard the GSXR650 swingarms work pretty good. Really, all im looking for are years and models that have swingarms that will fit in my frame without any cutting(to the frame). Can you guys help me out? Also im looking to lower my bike about 2 to 3 inches. How would i go about that without welding or cutting on the frame?
Thanks guys,
KT
Thanks guys,
KT
1981 Kawasaki KZ1000-K LTD
1983 Suzuki GS300L-D
1982 Suzuki GS300L-Z sold:(
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- testarossa
Re: Replacing swing arm, need some candidates
24 Sep 2010 23:26
I got a 1995 GSXR 750 swinger in my KZ1000, and I didn't "need" to cut anything, but I did need to add some mounting points. You will need some welding to accomplish it in almost every case. Once you convert to the mono shock setup, lowering the bike is easy. There are two connecting links on the sides of the shock linkage known as dog bones. Just get longer dog bones and you lower the bike.
I think that the easiest swing arm to adapt is the Suzuki GS1100. It will require you to have shock mounts welded to the top of the arm. Z1 actually sells some weld in lower shock mounts. You could get a welding shop to buzz them on for not too much cash.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
- porchev914
25 Sep 2010 00:06
Did you want to make it a monoshock, or mod the swingarm for duels? If you don't want to do any welding or cutting on the frame, you could wait for irishwill to finish a little something he's working on
kzrider.com/index.php?option=com_kunena&...imitstart=300#401360
FRANKEN Z!
- otakar
25 Sep 2010 04:54 - 25 Sep 2010 05:01
If you are looking to keep dual shocks on the bike than a Gs1100, or a Zr750/1100 or a Zrx1100/1200 swing arms will fit with minimal problems and you can keep the dual shocks.
GS100 swingarm.
ZR750/1100 swingarm
ZRX1100/1200 swingarm
GS100 swingarm.
ZR750/1100 swingarm
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 25 Sep 2010 05:01 by otakar.
