Swing arm identification help
  • Tuber
  • Tuber's Avatar Topic Author
24 Sep 2010 10:38
#401422
Could someone help me identify the swing arm on me racebike!
I have fitted a FZR750 front end on this morning. Perfect fit, no adjustments required. I may try and source an 18 inch front wheel instead of the 17 fitted.
Now looking at converting the back wheel. Can anyone help please.
[IMG
[IMG
[IMG
[IMG
Near Edinburgh
  • TerryK
  • TerryK's Avatar
Re: Swing arm identification help
24 Sep 2010 10:56 - 24 Sep 2010 11:00
#401431
Looks like a JMC arm to me. They are based in England. Actually now that I think about it, JMC doesn't use eccentric cam axle adjusters. Hmmmmm?
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
Last edit: 24 Sep 2010 11:00 by TerryK.
  • Tuber
24 Sep 2010 12:16
#401462
I thought the same at first. I just can't seem to find it.
Near Edinburgh
  • Tuber
24 Sep 2010 12:29
#401463
Found it,
Here is a link
www.metmachex.net/p3_10_1.htm
I will phone them and ask what else can fit/ supply.
Near Edinburgh
  • TerryK
  • TerryK's Avatar
24 Sep 2010 18:34
#401518
They sure know how to make beautiful bike parts in the UK!
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
  • 893cv
  • 893cv's Avatar
24 Sep 2010 21:35
#401554
Yes, JMC does use eccentric adjusters. Have a look!
www.swingarm.com/bikegallery.aspx
1980 kz1000 LTD
1978 Z1R
