Shorter handlebar: clearance issue with gauge
  • shimvalve
  • shimvalve's Avatar Topic Author
23 Sep 2010 06:47
#401128
I'm having a bit of a dilemma on my '81 kz550. I recently purchased some shorter bars (superbike bars) in place of the stock mini apes. All of the controls fit except that the right gauge is in the way of the master cylinder. In order to have symmetrical placement of the grips, the master cylinder/brake lever has to be tilted so the brake lever is 20 or more degrees above horizontal. If it weren't for the little nub cast on the bottom of the master cyl. that stops the banjo bolt from rotating I'd be golden.
Is there some way I can keep these bars on the bike and modify something to fit 'em?
Thank you
  • 9am53
  • 9am53's Avatar
  • homebrew, and some bbq
Re: Shorter handlebar: clearance issue with gauge
23 Sep 2010 07:17
#401134
I ahd the same issue, and just got a new master cylinder. I got one from a newer sportbike because they have the remote fluid reservoir which gives you a lot more room on the bar.
  • lobstermobster
  • lobstermobster's Avatar
23 Sep 2010 11:09
#401187
Take the tach off, you don't need it.
1981 kz650 w/ flux capacitor
  • Capt America
  • Capt America's Avatar
  • Born Bad
23 Sep 2010 11:18
#401193
There are probably several different master cylinders you could replace it with, or you could just take your dremel tool, or a file, and carefully remove that nub. A lot of masters never even come with one, and most of the older ones never had it either. Just insure the banjo bolt is tight, and support the line further down somewhere if you're worried about it moving. I've never seen one move with a bolt properly tightened.
Least that is what I'd do. :blink:
Capt A merica
1983 K1 750 twin
Ontario, Canada.
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
23 Sep 2010 13:11
#401210
Thank you
just remove the nub ? ;)
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
