Rear brake pads
  • johnny chop
  • johnny  chop's Avatar Topic Author
Rear brake pads
16 Apr 2006 21:12
#40082
Could someone tell me how thick the rear brake pads are supposed to be on a 78 Kawa 750 twin? any link to where I can get a set? Also how do I remove the caliper to replace them?? Thanks..JC
  • wireman
  • wireman's Avatar
Re: Rear brake pads
16 Apr 2006 21:15
#40084
can you post a picture of your caliper?;)
  • KZ_Rage
  • KZ_Rage's Avatar
  • Kentucky Bourbon Barrel Ale
Re: Rear brake pads
17 Apr 2006 09:30
#40190
Just two bolts with nuts on the back side, one bolt retaining the back side pad.
Don't know the specific thickness but if one pad is a lot thinner than the other then replace. If they are about an 1/8" thick I'd replace, pads are cheap, hospitals are expensive.
Go here to see breakdown of the brake:
Post edited by: KZ_Rage, at: 2006/04/17 12:31
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
2006 ZG1000A6F (Totaled)
2001 ZRX1200R (Sold)
  • securitygeek
  • securitygeek's Avatar
Re: Rear brake pads
17 Apr 2006 09:46
#40195
Put the socket on the nut on the inside of the caliper. On mine ('78 750 twin), I was stupid and tried to use a wrench on the front of the caliper, then I noticed that the bolt head would not turn all the way around, because of the design of the caliper. It did nothing but scratch the paint:angry:. THEN I noticed that there was room for a socket on the back side!:blush:
  • johnny chop
Re: Rear brake pads
17 Apr 2006 10:13
#40202
KZ Rage.........Can you repost that link so I can paste it please??
Thanks......JC
Post edited by: johnny chop, at: 2006/04/17 13:16
  • johnny chop
Re: Rear brake pads
17 Apr 2006 10:14
#40204
I'll take a pic & post it ASAP......JC
  • KZ_Rage
  • KZ_Rage's Avatar
Re: Rear brake pads
17 Apr 2006 10:23
#40207
kawasaki.com/Default.asp?strContentURL=/...talogID=2&intParts=1
If the link doesn't work go to Buykawaski.com through this link and then go through the selection process to get to your year and model.
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
  • johnny chop
Re: Rear brake pads
18 Apr 2006 09:35
#40485
OK..Got the link, thanks.........I took out the two bolts on the caliper then the two nuts. I thought the caliper would come right off but it didn't. Seems like the caliper piston is getting hug up on the front mounting bracket.(there's a hole where I think the pad goes). Is there a way to get the caliper off? Is it possible the piston is expaneded to far & it's frozen? I didn't see any brake pads,they must be really small..... Can anyone help me out with this rear brake change?? :blush: :blush:
Thanks in advance.....JC
  • KZ_Rage
  • KZ_Rage's Avatar
Re: Rear brake pads
18 Apr 2006 19:25
#40648
I'm at a loss for what you are referring to??
Once you take the bolts that hold the two halve together to the frame it should have just fell in to two pieces. I guess it is time for photos.
You should have removed bolt#14 and nut#2.
The pads are #9 & #10.
Post edited by: KZ_Rage, at: 2006/04/18 22:32
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
  • securitygeek
Re: Rear brake pads
18 Apr 2006 19:35
#40658
I think the rear caliper is a single peice. Take out the two bolts that hold it to the bracket and it should just slide off.
  • wireman
  • wireman's Avatar
Re: Rear brake pads
18 Apr 2006 20:17
#40675
yeah thats a front caliper used on rear .open the bleeder valve and put a hose on it to direct brake fluid into empty can or something then slide caliper towards drivers side this should force the piston back into caliper.then remove the 2 bolts and roll or pull caliper off of bracket.then blead brakes when you are finished reinstalling caliper.;) goodluck,happy wrenching!
  • johnny chop
Re: Rear brake pads
18 Apr 2006 20:24
#40676
The pads are #9 & #10.<br><br>Post edited by: KZ_Rage, at: 2006/04/18 22:32
Great a picture.... :cheer: I took out the bolts (#14) & the nuts (#2) with no luck. Do I also have to remove the phillips head screw (#6)the washer (7)& 8 to remove the inner pad? Should the outer pad(10) fall right out? Seems like the caliper piston is getting stuck in the circular part in the Y shaped bracket (where the pads ride)maybe that's the pad that's getting stuck.Sorry but I've never done this on a bike before only a car........:blush: Would it help if a took a pic ot two??...JC
