Rear brake pads
- johnny chop
Rear brake pads
16 Apr 2006 21:12
Could someone tell me how thick the rear brake pads are supposed to be on a 78 Kawa 750 twin? any link to where I can get a set? Also how do I remove the caliper to replace them?? Thanks..JC
- wireman
- KZ_Rage
- Kentucky Bourbon Barrel Ale
Re: Rear brake pads
17 Apr 2006 09:30
Just two bolts with nuts on the back side, one bolt retaining the back side pad.
Don't know the specific thickness but if one pad is a lot thinner than the other then replace. If they are about an 1/8" thick I'd replace, pads are cheap, hospitals are expensive.
Go here to see breakdown of the brake:
Post edited by: KZ_Rage, at: 2006/04/17 12:31
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
2006 ZG1000A6F (Totaled)
2001 ZRX1200R (Sold)
1984 KZ550F2 SOLD!
- securitygeek
Re: Rear brake pads
17 Apr 2006 09:46
Put the socket on the nut on the inside of the caliper. On mine ('78 750 twin), I was stupid and tried to use a wrench on the front of the caliper, then I noticed that the bolt head would not turn all the way around, because of the design of the caliper. It did nothing but scratch the paint:angry:. THEN I noticed that there was room for a socket on the back side!:blush:
- johnny chop
Re: Rear brake pads
17 Apr 2006 10:13
KZ Rage.........Can you repost that link so I can paste it please??
Thanks......JC
Post edited by: johnny chop, at: 2006/04/17 13:16
Thanks......JC
- johnny chop
Re: Rear brake pads
17 Apr 2006 10:14
wireman wrote:
I'll take a pic & post it ASAP......JCcan you post a picture of your caliper?
- KZ_Rage
Re: Rear brake pads
17 Apr 2006 10:23
kawasaki.com/Default.asp?strContentURL=/...talogID=2&intParts=1
If the link doesn't work go to Buykawaski.com through this link and then go through the selection process to get to your year and model.
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
1984 KZ550F2 SOLD!
- johnny chop
Re: Rear brake pads
18 Apr 2006 09:35
OK..Got the link, thanks.........I took out the two bolts on the caliper then the two nuts. I thought the caliper would come right off but it didn't. Seems like the caliper piston is getting hug up on the front mounting bracket.(there's a hole where I think the pad goes). Is there a way to get the caliper off? Is it possible the piston is expaneded to far & it's frozen? I didn't see any brake pads,they must be really small..... Can anyone help me out with this rear brake change?? :blush: :blush:
Thanks in advance.....JC
- KZ_Rage
Re: Rear brake pads
18 Apr 2006 19:25
I'm at a loss for what you are referring to??
Once you take the bolts that hold the two halve together to the frame it should have just fell in to two pieces. I guess it is time for photos.
You should have removed bolt#14 and nut#2.
The pads are #9 & #10.
Post edited by: KZ_Rage, at: 2006/04/18 22:32
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
1984 KZ550F2 SOLD!
- securitygeek
Re: Rear brake pads
18 Apr 2006 19:35
I think the rear caliper is a single peice. Take out the two bolts that hold it to the bracket and it should just slide off.
- wireman
Re: Rear brake pads
18 Apr 2006 20:17
yeah thats a front caliper used on rear .open the bleeder valve and put a hose on it to direct brake fluid into empty can or something then slide caliper towards drivers side this should force the piston back into caliper.then remove the 2 bolts and roll or pull caliper off of bracket.then blead brakes when you are finished reinstalling caliper.
goodluck,happy wrenching!
- johnny chop
Re: Rear brake pads
18 Apr 2006 20:24
KZ_Rage wrote:
I took out the bolts (#14) & the nuts (#2) with no luck. Do I also have to remove the phillips head screw (#6)the washer (7)& 8 to remove the inner pad? Should the outer pad(10) fall right out? Seems like the caliper piston is getting stuck in the circular part in the Y shaped bracket (where the pads ride)maybe that's the pad that's getting stuck.Sorry but I've never done this on a bike before only a car........:blush: Would it help if a took a pic ot two??...JC
Great a picture....I'm at a loss for what you are referring to??
The pads are #9 & #10.<br><br>Post edited by: KZ_Rage, at: 2006/04/18 22:32
