Want to get rid of air forks
- psrumors
21 Sep 2010 05:58
I tried searching but only came up with a thread or two and still have some questions
Do caps from non-air forks fit the air forks? If I am going to dump the air I might as well change the caps if it can be done.
I read someone had used PVC spacers for preload, is the PVC safe? Wont crack, deteriorate and leave shavings in the tube?
Is there a replacement spring so the spacer can be avoided?
Any reason NOT to get rid of the air? Currently it will only hold pressure for about a week.
'82 KZ1000-K2 LTD
- otakar
Re: Want to get rid of air forks
21 Sep 2010 06:26 - 21 Sep 2010 06:26
Yes Progressive has a set of springs for all of our bikes. The springs are variable rate, so they get stiffer as the fork compresses. Z1E can get them for you.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 21 Sep 2010 06:26 by otakar.
- otakar
21 Sep 2010 06:28 - 21 Sep 2010 06:30
By the way. Many of the Progressive springs also come with PVC spacers. I used a set of old valve springs as an additional pre-load on top of my springs. But why would you want to get rid of the air suspension?
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 21 Sep 2010 06:30 by otakar.
- psrumors
21 Sep 2010 07:33
They currently leak down over time and I like things simple. No more worrying with it.
'82 KZ1000-K2 LTD
- Tony
Author
21 Sep 2010 07:43
I removed the aircaps from my front forks. Replaced with normal caps and progressive springs. Works fine.
